HI All.
I have a set of Beovox 3705, 3 way speaker I inherited a while back. I can find virtually no information on these speakers. Can anyone help? I have a lot and serial number of the speaker set (Lot G, Serial 001132). On the sticker on one of the speakers I have found 4 Ohm 40 (75) W.
Thanks & Regards
Jan
There is no Beovox 3705 model. Probably 3700 or 3702?
Maybe with right model number you can find information you are looking for...
Theomaster
Vintage Bang & Olufsen
I'm 100% sure I have the right model number. Hence I'm battling to find info.
There was a discussion long time ago:
https://archivedforum.beoworld.org/forums/t/22249.aspx
sadly without pictures.
But even our guru was clueless
Maybe he has more info meanwhile...
hx
hemenex: There was a discussion long time ago: https://archivedforum.beoworld.org/forums/t/22249.aspx sadly without pictures. But even our guru was clueless Maybe he has more info meanwhile... hx
Interesting. Maybe I am wrong than.
Pictures would help us
How do I add a picture?
When you click reply you will see the OPTIONS tab at the top click it and you will see you can add a file or picture to your post.
Regards Keith....
