Beogram Polycarbonate dust cover
Not Answered This post has 0 verified answers | 12 Replies | 0 Followers
Beosince98
Silver Member
Beosince98 posted on Wed, Apr 3 2019 4:30 PM
I recently acquired a Beogram 4000 with a broken dust cover. I know that there are aftermarket dust covers available. However, there seem to be no "upgraded" covers, made from Polycarbonate. I know that people have talked about producing them, but is there anyone who actually had one made? If so, would you say it was worth the investment? Is the aluminium trim recessed in the cover, or only stuck on? As always, thank you for your help!
Dillen
Copenhagen / Denmark
ONLINE
I'm not sure, that I would see polycarbonate as an upgrade, really.
Polycarbonate is very resistant to breaking and it doesn't shatter if dropped, but like acryllic it will
build up stress patterns and eventually crack from stress.
It's not at all as rigid as acryllic (unless very thick), a large lid as on the Beogram 4000 would sag and feel cheap as it "flaps around".
It scratches and marres far too easily to be practical for this use in my opinion. You can even dent it if not careful.
It's not particularly resistant towards solvents in cleaning products.
It's also quite costly to produce and work with and it is generally considered to be very slightly toxic. Phosgene and chlorine is used in
production - neither is any good for us or the environment.
Ideally you should wash your hands every time after touching polycarbonate.
Beosince98
Silver Member
Thank you for your comprehensive answer, Dillen! Any experience when it comes to fit and finish with the aftermarket dust covers?
Søren Mexico
Mexico City
Beosince98:
Frede (classic audio) can provide correct dust cover https://www.classic-audio.dk/content/classic.php?page=dustcover
Dillen
ONLINE
Beosince98:
I've tried a couple.
FIt and finish varies A LOT.
The original dustcovers are cast in one piece. This is an extremely expensive production method unless you need thousands.
The aftermarket dustcovers I have seen were all glued together from individual pieces, top, sides etc.
The finish of the joints is particularly difficult, because you can see each and every little imperfection, misalignments, bubbles in the glue etc.
Beosince98
Silver Member
Thank you all very much! It is great to see how the B&O community can help! I have contacted a few shops that specialize on building custom. I will keep you in the loop with what I come up with.
Beosince98
Silver Member
After having taken exact measurements of the dust cover, I realized that the side walls are angled (not this: I I, but this / \). Do you think there is a reason for this, or is it a manufacturing error. I can not see a functional or aesthetic reason for doing so. Also, the measurements of my dust cover are not perfect, of by no more than 1mm, which i guess is a manufacturing error. Also, I am quite certain that the dust cover is glued, and not cast in one piece, as the seams are still very much visible.
matador43
Dillen:
Polycarbonate is very resistant to breaking and it doesn't shatter if dropped, but like acryllic it will build up
It's not at all as rigid as acryllic (unless very thick), a large lid as on the Beogram 4000 would feel cheap as it "flaps around".
Hi Dillen,
I wonder if the same applies to Beocord covers?
I should collect a Beocord 1200 with original cover and I want to refresh it a little. Is there a way of polish it, clean it and care it?
From the picture I've seen so far, it looks not broken but yellowish/brownish.
Tank you.
Beosince98
Silver Member
Polishing the Acrylic is possible, indeed. However, with my Beogram, the acrylic has become ever so slightly opaque over the years, which is not possible to fix. Also, some hairline cracks have occurred in various areas.
Søren Mexico
Mexico City
Check here
https://forum.beoworld.org/forums/t/14600.aspx?PageIndex=2
matador43
Hi Søren,
Of course I've been following your threads about your Beocord 1200 with great attention and was planning to get in touch with you as soon as I inspect the mine to come!
But I did miss that one. Look like lot of heavy work. I dont know if I'm gonna be able of such meticulous work.
Anyway, can you confirm  this is the very same material for beocords cover? Because the first post of Dillen imply that some material are really hard to work with and I know some stories where guys do apparently fantastic jobs reviving plastic things but who start to become opaque or brittle or dry some days after Surprise
Søren Mexico
Mexico City
The BG 1000 cover is still the same as after polishing it a couple of years ago, polishing is kind of boot camp, 3-4 hours of hard work. The BC1200 cover was less damaged and only went through the 3 Novus steps it still has some minor scratches and swirls: The BC 1200 cover feels a little harder to polish than the BG 1000. I dont see any yellowing on either of them
matador43
Thats great to hear!
I can't wait until it comes. Scheduled for tomorrow night!
Of course i'll post pics of it: as it's sold as defective I will ll need all good souls to help me make it work again! Big Smile
Page 1 of 1 (13 items) | RSS
