BeoLiving news & support from Khimo!
This post has 475 Replies | 20 Followers
Tassos
Athens
Posts 270
Tassos replied on Wed, Oct 28 2020 9:28 AM
Hello all,
I have been experimenting with a Beocreate 4C and an old pair of CX50s I have. The 4C is a great idea since it can play almost anything (roon, spotify, dlna, bluetooth, airplay, radio). Furthermore it can execute commands send via http. I have been playing around with this capability since today morning and I have to admit I am very happy with it. I have created macros for play/pause, next/previous track, mute/unmute, volume up/down. It could be said that it is almost integrated to my bli system. By almost I mean that the system doesn't "see" it as an A/V renderer (I tried to trick it but with no success) and as a result there are no sources. On the 4C side there is no command to start a source and as a result starting a source has to be done by your phone/tablet, etc.
Is there any way to make the bli "see" the 4c as an a/v renderer? And in case it can is it in your plans to make it happen?
Thanks a lot
Tassos
CTR
Denmark
Posts 11
CTR replied on Tue, Nov 3 2020 5:12 AM
Hi Iwan.
Are there any plans to integrate Ikea directly into BLI?
Would be so ingenious if curtains could be integrated directly
 Thanks for at great produkt
Christian
Seanie_230
UK
Posts 2,218
ONLINE
Ikea?
Can you post a link to the curtains?
Would be good if its possible in Essential mode :)
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
CTR
Denmark
Posts 11
CTR replied on Tue, Nov 3 2020 10:51 AM
https://www.ikea.com/gb/en/cat/electric-blinds-44531/
Workshop perfekt with HomeKit and Google assistent
What kind of binds do you boys have in your BLGW/BLI setup ??
ebnrob
UK
Posts 149
ebnrob replied on Tue, Nov 3 2020 11:18 AM
CTR84:
I've Somfy RTS Venetian blinds that I've linked up to my homeseer server via an RXCOM RFXtrx433E device, it works brilliantly for automations that open and closes them on sunrise, sunset, leaving home etc, but it would be nice to somehow manually control them in beoliving too but I don't think that'll be possible without some sort of custom driver in the BLGW.
ebnrob
UK
Posts 149
ebnrob replied on Tue, Nov 3 2020 11:25 AM
Khimo Support:
we are currently focused on a revamp of the app, it's coming out any day now! Can't wait to hear what you think about it :)
The revamped app on the iphone looks great @Khimo! Very polished and I like the new fonts. The double Source icon at the bottom left appears to be fixed tool which is great.
I'm wondering, is it possible for the app to remember what source is playing on a masterlink device? For example if I start Radio on my Bedroom beolab 3500 through the beoliving app, put the iPhone into standby, then wake the phone, the 'Select a source to start listening' shows as though nothing is playing in the bedroom? I'm using the BLGW.
Many thanks!
Griebel
Posts 399
Griebel replied on Wed, Nov 4 2020 10:04 AM
Yes, it looked great before I updated to iOS 14. Now all the room pictures are gone!
stefan
200 miles from Struer
Posts 2,885
stefan replied on Wed, Nov 4 2020 11:13 AM
I had Beoliving 2.0.0. (120) installed from the testflight and reported bugs via testflight feedback - no response.
Now I installed V. 2.0.0. from the appstore (official version I think) - same bugs are still there!
1- buttons with led in compact mode with overlapping text on the led (and now even worse: whole text (buttons?) are shifted to the right, so the right buttons are partly out of sight.
2- When starting the app, it firdt shows the message "This project has no resources" for 1-2 seconds
3- still no status function on shade buttons with state (KNX), as promised some time ago (tip: just redo the light button with state as a slider and a bit different design - maybe a horisontal slider with X% showing, that can be set to SHADE section (works already with light buttons in the LIGHTS section..)
https://forum.beoworld.org/forums/p/43575/317093.aspx#317093
Thank you
Stefan
Khimo Support
Posts 161
Griebel:
Hi Griebel,
Can you try to upgrade your BLI to 2.2.0.125?
Thank you for reporting!
Best,
the Khimo team.-
Khimo Support
Posts 161
stefan:
Hi Stefan,
Sorry for not answering your feedback on TestFlight Sad, we are working on a solution to the compact button (1).
Regarding 2, is this something that was happening before? Did you enable the app to access your location? We use location to speed up the connection.
Regarding 3, sorry, it is still in the backlog.
Thanks,
the Khimo team.-
stefan
Posts 2,885
stefan replied on Wed, Nov 4 2020 4:14 PM
Khimo Support:
stefan:
Hi Stefan,
Thanks,
the Khimo team.-
Now you were quick :) very quick:))
I have beta 2.0.1. installed and problem 1 and 2 solved!
To answer your question regarding '2' Yes, it happened in the prevoius version, too - and, yes, location access is (and was) enabled for Beoliving app.
For No.3: maybe my solution is worth thinking about - I have it already tested - works, but only in the LIGHTS section unfortunately...)
Thank you!
Stefan
Khimo Support
Posts 161
Regarding previous questions you have asked:
Tassos:
For BeoCreate 4C we do not have further integration in our plans at the moment.
CTR84:
We would like to be able to add integration to IKEA, the issue at the moment is that they have not yet released an official integration protocol. We do not lose hope that they will do so soon!
ebnrob:
If using Somfy shades, we do have a driver that integrates the BLI with the Somfy RTS Universal Interface and allows you to control the shades directly from the BLI.
ebnrob:
As we cannot access the state of the MasterLink product, we prefer to let the user define what the product is playing, than showing old information that might not be correct and cause confusion.
We are very happy to hear you are enjoying the new app! We are working hard to fix any issues you might possibly have while continuing to develop new integration possibilities. Don't hesitate to send us questions or requests, we always take them into account even if we might take some time to answer here :)
ebnrob
UK
Posts 149
ebnrob replied on Thu, Nov 5 2020 10:08 AM
Khimo Support:
Thanks for the explanation, am I correct in thinking the old MLGW can receive status updates from the players? If so would having the MLGW and the associated driver push ML status updates to the app?
Thanks for letting me know about the Somfy driver too, will this work on the BLGW?
Are there any plans to integrate with NodeRed? This would really open the door for third party integration.
Khimo Support
Posts 161
ebnrob:
The ML protocol driver enables sending commands, but not receiving source information. It is not part of the communications protocol and because of this, we cannot implement this functionality :(
ebnrob:
The Somfy driver is available for the BeoLiving Intelligence on PRO mode.
ebnrob:
We shall look into Node-Red! What kind of integration are you imagining?
Griebel
Posts 399
Griebel replied on Fri, Nov 6 2020 8:18 AM
Updated and the pictures came back. Great. Thanks!
CTR
Denmark
Posts 11
CTR replied on Thu, Nov 12 2020 4:46 PM
I want even more home automation in my B & o / BLI setup. have bought a Rasberry pi and now have to choose whether I should use Homeassistant, HomeBridge, NodeRed or ?? what do you use out there?
Anavt mk1 55
BS9000
Beoplay M3
NL/ML converter
BLI Pro
Munchen
Posts 21
Munchen replied on Sat, Nov 14 2020 11:06 AM
Is there a realistic chance that BeoLiving will support Apple Homekit in the upcoming future?
Khimo Support
Posts 161
Munchen:
We will release Siri integration soon, all the Beoliving scenes will be available to Siri using apple shortcuts and you will be able to create shortcut automation too.
Seanie_230
UK
Posts 2,218
ONLINE
Seanie_230 replied on Sun, Nov 15 2020 11:48 AM
Hi Khimo
Do you have a timeline?
Will the scenes be imported into HomeKit automatically?
Cheers
Sean
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
AndersKjergaard
Posts 5
Hi Khimo
I'm using the integration for LK IHC in my system. LK recently released a new dimmer, which i guess will replace previous versions. This functions in the same way as previous dimmers, but is not automatically imported to the BLGW. I can find the ID of the dimmer manually, but the BLGW will not let me add it, as it can not recognize the ID. Is there any chance you would look into this? As all lights in my house are controlled by these, this is a rather large setback,
Link to the dimmer: https://www.se.com/dk/da/product/820B1250/lk-ihc-led-dimmer-2-kanal-din-36mm/
Br
Anders
Munchen
Posts 21
Munchen replied on Mon, Nov 16 2020 7:12 PM
Khimo Support:
Thank you very much sharing your next steps regarding the integration into the Apple ecosystem with Siri integration. Sounds very promising. :)
But it sounds like half a step to me. When you are heading towards the Apple ecosystem, why not a full integration into Apple HomeKit? :(
Khimo Support
Posts 161
We expect Siri Integration to be live at some point during december.
@Munchen, what would you like to obtain from "full integration" into HomeKit?
Khimo Support
Posts 161
AndersKjergaard:
On the subject of LK, we are aware of the new dimmers, and LK is sending us the new hardware so we can develop integration with these devices. We will let you know as soon as there is news on this front!
AndersKjergaard
Posts 5
Khimo Support:
AndersKjergaard:
That great to hear. It is good that you maintain the integrations which are important to many users. While you are looking at the LK IHC integration, it would be nice to know why temperature control is not supported. I guess there must be a good reason, since it is an important part of the BeoLiving as well as IHC.
Br Anders
Tassos
Athens
Posts 270
Tassos replied on Wed, Nov 18 2020 1:33 PM
Hello all,
I was wondering if it is possible to trigger a macro from the widget screen of an iphone/ipad. I am asking cause I think it will be very convenient for macros that are used often. For example my garage door is connected to the BLI and in order to open/close it I need to unlock my iphone/ipad start the application go to scenes and press trigger the macro. Furthermore I have to do the same thing to open the main door of my house when someone is ringing the bell and I do not have a beoremote close by.
1990
Posts 495
1990 replied on Wed, Nov 18 2020 2:44 PM
Hi Tassos,
You can via the new iOS Shortcuts (see https://www.youtube.com/watch?v=jn2jql_Z_uo)!
Khimo Support
Posts 161
Yes indeed! Shortcuts ( https://khimo.github.io/bli-guides/how-tos/howto-siri-shortcuts ) can be added as a widget, and this will be even easier as soon as the Siri integration we mentioned a couple of days ago comes out :)
Tassos
Athens
Posts 270
Tassos replied on Thu, Nov 19 2020 7:03 AM
Thanks for the answers 1990 and khimo support will try it asap!!!!
Tassos
Athens
Posts 270
Tassos replied on Thu, Nov 19 2020 7:39 AM
Hello again,
a quick question, how can you trigger the action via the shortcut when you are remotely connected?
Thank you
1990
Posts 495
1990 replied on Thu, Nov 19 2020 8:29 AM
I think you can control it remotely if you have a HomeKit hub (Apple TV or dedicated iPad).
@Khimo: now the Contour has been released is there any chance we’ll get the Home Control screen on the Stage/Contour?
Munchen
Posts 21
Munchen replied on Thu, Nov 19 2020 12:56 PM
Khimo Support:
I would like to integrate my B&O equipment into my HomeKit automations. E.g. leaving the house. Apple homekit would not only turn off all lights and reduce the temperature additional I would love to trigger that all B&O systems turn off.
All Smart Home devices I use are supporting Apple Homekit, but not all are supported by Beoliving like Netatmo, eve or tado.
CTR
Denmark
Posts 11
CTR replied on Fri, Nov 20 2020 3:49 PM
Hi Khimo
Can you help with a picture of a BLI macro, where you use the Openweather API ?
And is it possible to show the current outdoor temperature on the Webpanel, instead of the dummy temperature??
Thank you for a great product, and your part in this forum.
Khimo Support
Posts 161
Tassos:
Yes, you could probably get it working via a HomeKit Hub, but in our next update you will be able to easily (one-step) add the BLI's scenes to Shortcuts and activate them remotely through Khimo (PRO BLI or BLGW).
1990:
We can (very happily) confirm that the Home Control screen will be available on both the Stage and the Contour in their next software update!
Munchen:
You could do this by adding a Shortcut to your HomeKit automation scheme that turned off all your B&O equipment :)
Khimo Support
Posts 161
CTR84:
Hi CTR84,
It is not possible to show the temperature on the webpanel, I'm not really sure what you mean by dummy temperature...
Also not sure what you would like to see about the OpenWeather driver in use. It is normally used as trigger for Macros, you can see all the parameters in the documentation.
You could also use the information it provides as a conditional with lua macros. E.g. check if it is raining and condition some action in your macro on this:
current = engine.query("Main/global/_CURRENT_WEATHER/current_weather")
if current[1].get("_Rain") == "true" then
   Do something
end
CTR
Denmark
Posts 11
CTR replied on Fri, Nov 20 2020 9:45 PM
Hi Khimo.
Thank you for a very fart reply.
Please see pictures for “dummy driver” temperature
CTR
Denmark
Posts 11
CTR
Denmark
Posts 11
CTR replied on Fri, Nov 20 2020 9:53 PM
CTR
Denmark
Posts 11
Khimo Support
Posts 161
Hi Again CTR,
It is not possible to configure the temperature of a dummy thermostat.
They are not meant for this purpose, and a thermostat's temperature is never changeable as it should reflect the measured temperature.
Seanie_230
UK
Posts 2,218
ONLINE
Any idea when the update will be?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 9 of 12 (476 items) « First ... < Previous 7 8 9 10 11 Next > ... Last » | RSS
