BeoLiving news & support from Khimo!
This post has 212 Replies | 13 Followers
Khimo Support
Posts 86
Normann:
In the BeoLiving app (version 1.5.4.533) I no longer have the possibility to log on to Tune In or make   choice on selecting a radio station.
We just reproduced the problem, we are working to solve it.
Normann
Posts 256
Normann replied on Mon, Mar 9 2020 7:30 PM
Khimo Support:
Normann:
Thank you for the quick respons Smile
Tassos
Athens
Posts 176
Tassos replied on Thu, Mar 12 2020 9:05 AM
Hello Khimo Team, can you give us any information on Beosound Balance and how it is going to be integrated (if it is going to be integrated) with the BLI?
Thank you
Tasos
Khimo Support
Posts 86
Normann:
Today we released a new version that solved the TuneIn issue that we were able to reproduce and some other minor issues. Please, after updating it, let us know if it is working better for you.
Khimo Support
Posts 86
Tassos:
Hi @Tassos,
As we commented before, the current version of BeoSound Balance is not integrated with BLI. This does not mean, in any way, that we will not integrate future B&O products.
Best,
the Khimo team.-
Tassos
Athens
Posts 176
Tassos replied on Fri, Mar 13 2020 7:46 AM
Hello Khimo Team, any news on the support of third-party TVs....?
Oh and thank you for the prompt response on the Beosound Balance question.!!! :-)
Millemissen
Flensborg, Denmark
Posts 12,840
ONLINE
Khimo Support:
....the current version of BeoSound Balance is not integrated with BLI.
Best,
the Khimo team.-
’current version’......that sounds interesting ;-))
Normann
Posts 256
Normann replied on Sat, Mar 14 2020 9:17 PM
Khimo Support:
Normann:
Hi.
Looks like you have solved the problem .. Big Smile
kmortenesi
Posts 26
Hello. I am using BeoLink 2 app with no problems. I installed the BeoLiving app but it is unable to connect to by blgw. It finds it immediately but the admin username and password doesn’t work. I can access my blgw just fine from my laptop and BeoLink 2 app. Is there a good reason I would go with the new app? I have various B&O equipment (NL only), as well a Lutron light control.
Thanks!
morten
minority
Posts 1
Silver Member
minority replied on Mon, Mar 23 2020 9:10 AM
Khimo Support:
Hello everybody!
We are glad to announce that you can now directly integrate Google Assistant with the BeoLiving Intelligence. You will find it listed inside Google Assistant, Home control settings.
Please, let us know how it is working for you!
Best,
The Khimo team.-
Hi! I recently setup my BLGW and have been slowly learning how to configure it. I can't stop smiling when I use it. One of the things that intrigued me was the ability to control my B&O things at home by voice. I have been playing with Google Assistant to turn on a scene via IFTTT, but I've only found the ability to add one IFTTT app to control a scene. This works very well, but I would like to add more Smile;
As per the documentation on voice control, apparently only Alexa is officially supported and the list of commands is extensive. I aimed to achieve the same by adding a IFTTT app for each of the actions I want.   I am new to IFTTT, but am I approaching this all wrong?
My second question relates to the Fibaro driver, relay switches and dimmable switches -
  • Switches that are dimmable appear as lights in the BeoLiving app, as well in Google Home
Switches that are dimmable appear as lights. I can turn them on with Google Assistant - but the light turns on with 0% brightness, and then I have to set the brightness. Normally the dimmable light should turn on and then back to it's previously setting. Also in the BeoLiving app, I can't just turn on a light to it's previous setting, I have to move a slider to the right percentage.
Is this as it should be? (and why?)
  • Regular relay switches don't appear at all - they can only be used if you create a scene
I have some lights that are not dimmable and use a regular relay switch. These are not seen as lights in BLGW, but I would like them to appear as lights in the BeoLiving app. Is there any way to change this? The second issue is, if they are not lights, they don't appear as such in the Google Home, with no way to control them.
Hoping you can provide some advice!
Kind regards,
Kasper
JensHauge
Posts 6
JensHauge replied on Wed, Mar 25 2020 10:18 PM
Hi Khimo support,
1st quistion:
I've connected my BLI with my KNX system and want my outdoor light to turn-on after sunset and turn off at 10pm - which works fine with a Macro in BLI.
Now my issue: after 10pm I want my outdoor KNX PIR to turn on lights 15min in the hours bewteean 10pm until sunrise with a 2nd macro.
how do do a Macro with an "AND" condition as the EVENT trigger i.e. as I need 2 conditions to be fulfilled??
[EVENT1] if PIR trigger yes
"AND"
[EVENT2] the time is between 10pm and sunset
[COMMAND] then do then do XXX
2nd quistion:
I've programmed my KNX Wall switch to turn on my B&O sound system in each room (e.g. start spotify) but is there any possibility to get a "text" back from the B&O Core with the Song title or Radio program that I can add to my KNX swithc?
3rd quistion:
Any plans to allow to us change and modify the Icons on the BLI iPhone APP?
e.g. my wife dont associate the B&O CORE sound system as hidden in a closet with the BeoLab speakers - e.g. it would be more natural with an icon of the actual speaker (e.g. Lab17 in the kitchen and Lap18 for the livingroom etc.) to represent the sund system
for the lights in each room it would great if we could add an ICON as well to visualize what type of lamp a button represent - i.e. if a cealing light, floor lamp, spot etc.
Thanks for the support - happy BLI user!
Jens
kmortenesi
Posts 26
For Q1 you can easily configure separate system modes and the have macros only fire in certain modes. I e.g. have two modes: HomeDay and HomeNight. These are automatic set based on time of day. I have a macro that sets up my living room lighting when I push the Netflix button, but only if mode is HomeNight. Works great
L Spad
Brighton
Posts 180
ONLINE
L Spad replied on Fri, Mar 27 2020 8:25 AM
Hi there, I know this thread principally focuses on the BLI, but I was wondering if there was any support to make use of the IR input on the BeoLink Gateway? It would be great to use that as a resource to trigger macros etc. Is that a possibility?
Page 6 of 6 (213 items) « First ... < Previous 2 3 4 5 6 | RSS
