connect turntable to BV7 and BL7.2
Answered (Verified) This post has 1 verified answer | 7 Replies | 1 Follower
gregbxl
gregbxl posted on Wed, Nov 28 2012 2:10 PM
hello everyone,
I use my BV7 (mk2) and its loudspeaker 7.2 as my main media center (tv, dvd and cd of course but itunes/spotify music as well through my macbook connected via DVI and 3.5jack)
I would like to buy a turntable and use it with my existing set-up. Is it possible to connect a turntable directly to my BV7 or the 7.2 (as it is active loudspeaker) or does it require a (pre-)amp with a phono socket?
thanks a lot,
Greg
stefan
200 miles from Struer
Answered (Verified) stefan replied on Thu, Nov 29 2012 3:44 PM
Verified by Puncher
If there is no audiomaster in your setup, a Beolink converter 1611 should work - directly connected - on the Masterlink end - wit your BV, and the AUX plug connected to a BG3500, 4500, 6500, 7000. You will need one of these BGs, because they have a built in RIAA preamp.
Should also be possible to control the BG with your Beo remote.
Another solution:  audio connection via scart - rca - 7 pi DIN - adapter and assigned as a video source (V.MEM, DVD, DVD2...)
Pressing AV - videosource activates BG port, but you won`t be able to control the record player. ABG with builtin RIAA is also necessary.
Stefan
Large48
You could use a 5500 amp (with late software) and turnable with a 1611 connector to connect the ML and Aux together and then N-MUSIC (I think) to get the phono on the BV7.
elephant
AU
Large48:
as an alternative, is it possible to connect the turntable to the PC's line in, and use the existing PC connection into the BV ?
what turntable do you have ?
BeoNut since '75
stefan
Verified by Puncher
Stefan
elephant
AU
stefan:
And the same constraints if he chooses the Mac route ?
Advantage of the Mac route would be to also start capturing the vinyl as digital media -- I tried it once but gave up as I lacked the patience.
stefan:
if he has an existing Beoport setup - does that count as the audiomaster ?
OK, no Beoport to worry about Wink
BeoNut since '75
stefan
stefan replied on Thu, Nov 29 2012 10:06 PM
-And the same constraints if he chooses the Mac route ?
Advantage of the Mac route would be to also start capturing the vinyl as digital media -- I tried it once but gave up as I lacked the patience.-
Agree. I have a BS5 and I have my favourite vinyls ripped to wma lossless, as I`m a lucky owner of an Avid Pro Tools HD system...:)
- if he has an existing Beoport setup - does that count as the audiomaster ?-
Beoport can act as an audiomaster - as far as I know - and the PC input of Beoport has no datalink. Only way to control a Beogram would be using an audiomaster like BM5500,6500,7000,4500,3500, BC2500, older BC2300, Ouverture or Beolink converter.
Stefan
Vienna
make an educated guess
Vienna replied on Thu, Nov 29 2012 10:51 PM
gregbxl:
If only manual operation of the turntable is needed, you can connect eg. a "Pro-Ject Debut Carbon Phono USB"
DIRECTLY via PHONO/RCA/CINCH to "RED"=right and "WHITE"=left of "Camera In"
Alternatively via a SCART camera adaptor  "3 x PHONO/RCA/CINCH <> SCART" to a SCART of your TV.
http://project-audio.com/main.php?prod=debutcarbonphonousb&cat=turntables&lang=en
If you choose a turntable without an internal "Phono Preamp", an external "Phono Preamp" like the Project
Audio "Phono Box S" is necessary between the record player and the TV.
http://project-audio.com/main.php?prod=phonoboxs&cat=boxes&lang=en
gregbxl
thanks for the replies.
I don't have any turnable yet, and yes, i was thinking of a Pro-Ject (because of the pure design... ?)
I understand from all of you that an amp is necessary even if the loudspeaker is active.
So can I imagine a ProJect Debut turntable connected to a phono box then connected via aux-in to the PC line-in ?
thanks
Greg
Page 1 of 1 (8 items) | RSS
