Anyone?
Robin: Aussie Michael: Quite an emotional campaign there Rob. Thanks for posting. Well yeah. Even thought I probably can’t afford it still have a desire in new stuff. I’m still not sure about that tv thing. There is no hint (in my opinion) whatsoever. There are only soundsystems shown (from the past) and the invitation only states about revolutionary movement and sound. Nothing about picture 🤷♂️
I was thinking exactly the same thing, seems like an audio product from what has been said. Whatever it is, am looking forward to seeing it and learning for certain what it is.
The logo has puzzled me too, especially since there really is only one correct way of putting it on a product. However, it was put on top on the LX series of televisions on a thin aluminium profile similar to the picture shown. Another thing worth noticing is the 45-degree mitred corner assembly of the aluminium parts, so far this tricky technique has only been used for Beovision frames.
Razlaw:The more I look at the picture, the more I wonder if the Bang and Olufsen logo is on the front, and not the top as it appears in the picture. I can not think of any B and O product that says Bang and Olufsen on top as opposed to the front.......
We will probably be disappointed when we see the result. That's how it has been for a long time.
Peter Pan:We will probably be disappointed when we see the result. That's how it has been for a long time.
Whatever it turns out to be and whatever moves, I hope there is some purpose to it - i.e. the movement does something (even remotely) useful, e.g. like opening the doors as you approach (BS3000 etc.).
What I hope it isn't, is irrelevant movement, or movement for movements sake, like the rising of the BV4-85/103 - which was absolutely pointless - why does your TV need to be at carpet level when you're not watching it!
Ban boring signatures!
Duels:It’s on the top on the BL18.
Razlaw: Whatever it is, we should know tomorrow.
Monday for the press :-)
https://www.wallpaper.com/lifestyle/bang-olufsen-beovision-harmony-tv
there you go one and all...
BeoVision Avant55 Mk1; Theatre with BeoSystem4; BeoSound2; BeoPlayA9; BeoPlayA6; BeoPlayM5; BeoPlayE6; BeoPlayH3 ANC
..and it all started 15 years ago with a pair of B&O A8 Earphones...
Sandyb: https://www.wallpaper.com/lifestyle/bang-olufsen-beovision-harmony-tv there you go one and all...
Well done...beat me by 1 minute!
