Beosound Essence remote disassembled
Not Answered This post has 0 verified answers | 12 Replies | 4 Followers
leosgonewild
Helsinki, Finland
Silver Member
leosgonewild posted on Sun, Mar 24 2019 10:21 AM
Pictures in order. Do note you will not be able to put it together again due to the bearings.
CB
> You are Here <
CB replied on Sun, Mar 24 2019 2:42 PM
What happened ?
leosgonewild
Helsinki, Finland
Silver Member
Wheel was a bit stuck, and I was curious.
beojeff
USA
I have one with a rather tight wheel. Were you able to make yours turn more smoothly and how?
leosgonewild
Helsinki, Finland
Silver Member
I need to get a hold of some magnets in order to reassemble the bearing. Will update on it when I get around to it.
That gunk is cause by me. I filled it with weapon oil before opening it. I was hoping it would lube the bearing.
But I suspect that the deal on the bearing is not good enough, causing the grease in the bearing to dry out and harden.
beojeff
USA
leosgonewild:
I'm glad you told me that. For a moment, I had considered using WD-40, but I had a feeling it wouldn't be a good idea.
leosgonewild
Helsinki, Finland
Silver Member
I remember someone had spilled some drink on the remote, causing some discoloration under the plastic plate with the logo. At least that can be easily removed with a spider to be cleaned.
It is made of plastic, and glue holds it in place.
laseralex
Thanks so much for this!
Would you mind taking a close-up photo of the square chip on the side with less components?  That's likely the main processor and I am very curious to know what part they used.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x Essence Remote  • 1x Beoremote Halo
Kelwin
Cambridge
Kelwin replied on Tue, Mar 2 2021 10:51 AM
TI CC2541 - Bluetooth LE chip https://www.ti.com/product/CC2541
laseralex
Kelwin:
Thank you so much!
Interesting little part.  It includes a little proprietary 8051-based microcontroller.  That's an old and slow slow processor, but it really doesn't need much for what it's doing: four buttons and a wheel!  (And slower = longer battery life.)  It only costs $1.60 in quantity.  Nice!
AndersKjergaard
Is it not possible to pull out the outer race of the bearing and replace the complete bearing?
I just disassembled an M5 this weekend. The bearing in the volume control was just a standard closed bearing, which yours also seems to be (at least until it disintegrated..).
TWG
TWG replied on Wed, Mar 3 2021 4:13 PM
AndersKjergaard:
Hope it's possible as 2 of my Essence remotes are leaking fluids... what a shame in quality. :-(
Fansastic
The Hague, The Netherlands
My remote fails to control the volume, any idea if this can be fixed?
Page 1 of 1 (13 items) | RSS
