Beosound Essence remote disassembled
Not Answered This post has 0 verified answers | 7 Replies | 3 Followers
___
___ posted on Sun, Mar 24 2019 10:21 AM
Pictures in order. Do note you will not be able to put it together again due to the bearings.
CB
> You are Here <
CB replied on Sun, Mar 24 2019 2:42 PM
What happened ?
___
___ replied on Sun, Mar 24 2019 3:52 PM
Wheel was a bit stuck, and I was curious.
beojeff
USA
ONLINE
I have one with a rather tight wheel. Were you able to make yours turn more smoothly and how?
___
___ replied on Sun, Mar 24 2019 8:44 PM
I need to get a hold of some magnets in order to reassemble the bearing. Will update on it when I get around to it.
That gunk is cause by me. I filled it with weapon oil before opening it. I was hoping it would lube the bearing.
But I suspect that the deal on the bearing is not good enough, causing the grease in the bearing to dry out and harden.
beojeff
USA
ONLINE
leosgonewild:
I'm glad you told me that. For a moment, I had considered using WD-40, but I had a feeling it wouldn't be a good idea.
___
___ replied on Mon, Mar 25 2019 6:46 AM
I remember someone had spilled some drink on the remote, causing some discoloration under the plastic plate with the logo. At least that can be easily removed with a spider to be cleaned.
It is made of plastic, and glue holds it in place.
laseralex
Thanks so much for this!
Would you mind taking a close-up photo of the square chip on the side with less components?  That's likely the main professor and I am very curious to know what part they used.
2x Beosound Moment
4x Beosound Essence Mk II
3x Beolab 8000
1x Beolab 6000
1x Beolab 3
3x Beolab 2
3x BeoPlay M5
1x BeoPlay A6
8x Essence Remote
Page 1 of 1 (8 items) | RSS
