Beomaster8000 repair/resoration
Not Answered This post has 0 verified answers | 61 Replies | 2 Followers
ALF
AUS
Silver Member
ALF posted on Thu, Mar 21 2019 8:53 AM
greetings ALL 😁
I decided to start a new thread with my new donor-unit BM8000 - this time in the correct forum !
this donor unit was purchased as a parts-reservoir but turned out in very nice cosmetic condition.
so I took a close look and noticed all boards were recapped, the displac is fine....well, so far so good.
further testing reveiled there are issues:
Plugged in it shows the StBy dot.
turning on, no relay clicking while the display comes on.....hmmm ?!
checked the power supply board....all associated transistors have tested fine off-board, all caps are in the correct way, all connector joints have been reflown.....?!
next thing I noticed the small heatsink with the 3 voltage regulators is getting VERY warm....?
next thing : with no relays energized I can measure the 15V and -15V regulator which should only be possible
when the start-up circuit gives the “green light”.
5V should be present at Pin14 / 9IC4 during STBY mode and going down to ‘O’ when ON is achieved....no, it remains at about 25mV
meaning: the BM according to this is actually out of ST BY !!
5V are only present at the 5V regulator when I disconnect P76 of the processor board ?
a faulty processor 9IC4 ??
I did change the two 2MHz crystals (as suggested as a precautional measure by Beolover) after removing
both uPs for safety reasons......! No change !
I disconnected the keyboard in case the on/off key is stuck and used the remote to turn off/on  the BM....
no luck here either 😡
disconnected P51 and 50....no change.
well, what am I missing here ?
and this is only unexpected work at the donor-unit while waiting for those speaker switch replacement to
continue work/repair/restore on my original BM8000 project...😳
guess help is badly needed here 🙄
chartz
Burgundy, France
chartz replied on Wed, May 22 2019 9:28 PM
Incredible! Phew!
Jacques
ALF
AUS
Silver Member
ALF replied on Thu, May 23 2019 12:59 PM
Well,
there is still the BM8000 donor unit........probably another high-speed project ?
Not sure yet how much effort is necessary to bring it back to life....we’ll see
and if, no doubt there will be posts 😁😁 and in between the odd relaxant   🍷🍷
ALF
Page 5 of 5 (62 items) < Previous 1 2 3 4 5 | RSS
