BeoSound 9000 Aux Port
Not Answered This post has 0 verified answers | 7 Replies | 2 Followers
MisterDarlin
MisterDarlin posted on Tue, Mar 19 2019 3:26 AM
Is the BeoSound 9000 aux port input or output? Can I use it as a line out with an adapter? Or can I only use the headphone jack?
beoaus
beoaus replied on Tue, Mar 19 2019 5:22 AM
Yes, with the correct cable.
Goodluck Beoaus.
PaulGiles
We have used this port when connecting to SONOS connect when the BS9000 is connected to speakers to incorporate into a SONOS system for the rest of the house.
Works well.
Beosince98
The aux connector is for connecting auxiliary equipment to the Beosound 9000, and therefore is input only. You can get output via the power link at the back or the headphone jack.
MisterDarlin
Beosince98:
Noted. Does one powerlink port carry a stereo signal? Would this cable do the job?
https://soundsheavenly.com/bang-olufsen/110-329-5-pin-din-to-twin-rca-powerlink-compatible-to-non-bo-hifi-amplifier-receiver-etc-din-to-twin-phono.html#/2-length-1m
Steve at Sounds Heavenly
The cable workshop, Leics, UK
ONLINE
Please note that the Aux port on the Beosound 9000 is both an input AND an output.  It can be used either to send a stereo source into the 9000 (ie. to add an iPod or Sonos player to the B&O system), or to give a line level (not volume controlled) output from the 9000 to an external system (eg. to play CD and radio from the 9000 to Sonos players in other rooms).
The difference between the output of the Aux socket and the Powerlink sockets is as follows:-
1) The Powerlink outputs are affected by the volume level of the 9000, whereas the Aux output is not
2) Different wiring is needed in the cables for each socket, so you need the correct cable for Aux Out or Powerlink Out
Both the Powerlink and Aux sockets carry stereo signals (ie. left and right audio within one socket).  Powerlink is an output only.
Please feel free to get in touch via my sponsor link below if you need any help with the correct cables to connect to the 9000 and I will be pleased to assist.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Peter
Siemianowice Sl., Poland
Peter replied on Tue, Mar 19 2019 1:32 PM
it works both ways pins 1,4 are out while 3,5 are in, pin 2 is gnd
Beosince98
I apologize for my false answer to your question!
Page 1 of 1 (8 items) | RSS
