If they work they sound absolutely fab.
but.....
quite often I have one of these two problems (or even both)
1) No wifi connection, so no way of controlling it via the app. where as my home wifi network is stable.
2) No sound/activity at all. They are connected through a high end RCA cable to my Marantz SR8012 receiver.
and it drives me crazy up to the level as being ready to sell them off. Despitethe great sound.
any thoughts, help?
thanks
Peter
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Hi Peter
cabel is way to go, I had these problems in the beginning, but after 3 days, I went with cables. My BL50s has run flawlessly since- 3 mouths now.
I am running BeoVision Eclipse 65 wisa to bl50 and bl18, no problem what so ever.
br Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Try a LAN over Powerline. Devolo/D-Link etc..
Much better/solid connection than wifi and with the right model you can power-through the Adapter to your BL50 master.
https://www.amazon.co.uk/Devolo-8385-MAGIC-STARTER-2400MBPS/dp/B07H5YPC7D/
Cheaper models available.
I find it just hard to believe that B&O still can't seem to figure out how to do WiFi in this day and age, and on a product as expensive as the BL50! The WIFi on my $500 Auralic Mini works flawlessly, ditto on my $500 Samsung TV.
I think B&O would be better served by never having put WiFi in high end speakers, rather than putting in WiFi that doesn't work. All that does is frustrate owners and lead to public relations problems for B&O. The idea of it is great but only if the execution is also great.
Jeff
Thanks all
I will indeed go through the nasty process of adding a network cable through my setup. It needs a few hours of cabling work unfortunstely due to a nasty setup of my living. I am comfortable that the wifi issue will be solved.As for the Marantz/no sound issue. I will change RCA outputs to see if that helps.Otherwise I am still puzzled.
Thanks guys for your supportMuch appreciated
Pathetic indeed. Guess it is time for me personally to completely give up on B&O.
Peter Dorr:I will indeed go through the nasty process of adding a network cable through my setup.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Library: A6, Beocom 6000 Bedroom: M5 Office: Beocom 2 Travel: Beoplay E8 2.0, Beoplay P2
Esax:Why not apple airport express
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Michael: Esax: Why not apple airport express Or these small TP-link. I use them a lot with devices that fail on WiFi. They can be used as bridges. Meaning take WiFi and send it on over Ethernet to the speakers. Cheap and EXTREMELY small. Just about 5x5 cm. Can be powered over usb. So probably doesn’t even need power from the wall, only from Beolab 50.
Beolab 50.
I may be incorrect but I think those devices take a lot of bandwith from the WIFI in the backhaul.
With Powerline adapters no WIFI is involved.
I'm also having the same issues and it annoys the hell out ot me. I have an eclipse and have then connected via WISA. All the other products in the range work ok on WIFI like my core and eclipse.
Whats the link for the TPLINK modules.
Beovision Eclipse 55 Brass Edition with Oak covers and Brass Orbital stand
Beolab 50s silver & Oak, Beolab 18 Brass with Smoked Oak, Beolab 18 Rose Gold with Maple Covers, Beolab 19 Black.
