How many 1611 converters can be used in a master link network?
Answered (Verified) This post has 1 verified answer | 25 Replies | 1 Follower
Luke Spadavecchia
Brighton
Luke Spadavecchia posted on Sun, Mar 10 2019 10:21 AM
Hi all,
I'm hoping to add another 1611 converter to my existing master link network, and I'm having some difficulties. Before I start messing around with the configuration too much I just want to be sure what I'm attempting is possible. I already have one 1611 in the network to connect my beosystem 7000. In addition to that one I'd like to add another 1611 to send datalink commands to a lintronic converter (as per the application note here http://www.abo-center.dk/Abo_center_2/reptips/diagrammer/Link/Lin%20Tronic%20Interfacing%20.pdf). Is more than one 1611 permitted in the network?
Here's a basic schematic of what I'm trying to do:
[Beomaster 7000]--<datalink>--[1611]--<masterlink>--[masterlink network]--<masterlink>--[1611]--<datalink>--[Lintronic]--<RS232 to USB>--[mac mini]
i need two 1611s because the Beosystem 7000 is located in a different room to my computer.
Luke Spadavecchia
Brighton
Hi all,
Just hooked up the 1614 converter and... IT WORKS!!
This is likely to be of pretty limited interest to others as it is somewhat setup specific but I can confirm the following:
1. You can use a 1614 converter in the same network as a 1611 converter with no conflicts.
2. You can use a 1614 converter or a 1611 converter as an interface for the Lintronic converter as per the application note above.
3. The beolink video cannot be used to sample commands from the master link to the intronic in the same was as the above converters. It can however be used to put commands onto the masterlink as described in the application note above.
Thanks to everyone for their help, support and useful suggestions
Guy
Buckinghamshire
Guy replied on Sun, Mar 10 2019 11:12 AM
I have never heard of any limitation in 1611 converters within a system - as long as you only have one audiomaster on the 'network' then I would think it would work.
Perhaps you could experiment with B&O's interactive Product Configuration Guide, and keep adding systems that require 1611s until it tells you that you have exceeded the maximum!  I would try, but I can't get the guide to run on Win10.
RaMaBo
near Munich
RaMaBo replied on Sun, Mar 10 2019 12:45 PM
even when you get trouble with the two 1611 in your masterlink network you could try a Beolink Video 1615 to connect the lintronic to the Audio aux connector.
This is just a gues but might a solution for your problem and a 1615 is quite cheap.
Ralph-Marcus
RaMaBo
near Munich
RaMaBo replied on Sun, Mar 10 2019 1:06 PM
Just tried the Product Configuration Guide:
If Masterlink is selected to link rooms, one can't select 'old' audio devices (to enforce the use of a 1611). But it is possible to add several 1615 to connect a MX4000 for example.
Ralph-Marcus
Luke Spadavecchia
Brighton
Thanks all,
I made up the custom connector correctly today (I'd previously mistaken pin 6 for pin 7 of the Data Link socket) and tested this.
I've tried this with the audiometer (Beomaster 7000) in various option settings but no dice. I think the system is having a hard time working out where to send audio commands with the two1611 units connected. Depending on the order I power on I can get either of the 1611s to work as I'd like, but not both simultaneously.
If the 1611 connected to the Lintronic is powered on first, I can send data to the mac mini - in this case controlling iTunes when N.Music is selected. However, the Beomaster 7000 does not power up (for any audio source).
If the 1611 connected to the Beomaster 7000 is powered up first then it powers up and I can play any audio source, but the 1611 connected to the Lintronic no longer passes the commands through.
Ralph, I'll see if I can get hold of a 1615 to try - does the 1615 pass audio as well as video commands? I'm not sure I understand your second comment correctly.
Thanks for the suggestions and help - and yes, this is a lot of effort to allow me to skip tracks in iTunes without getting my mobile phone out and firing up the apple Remote app!
All the best
Luke
RaMaBo
near Munich
RaMaBo replied on Sun, Mar 10 2019 6:20 PM
Hi Luke,
the 1615 does only transport the audio signal and the Datalink signal to and from a B&O TV, and converts it to masterlink.
The video signal itself will be transported via the antenna cable. But video is not needed in your case and the masterlink network doesn't care if the video transfer is done correct or not (which is the case in this scenario).
Concerning the Product Configuration Guide: It's just not possible to have an Audio System (a 1611 in your case, because it would act as an Audiomaster) in a Link room). There can only be _one_ audiomaster in the masterlink system, in your case the Beomaster 7000.
I hope it's now a bit more clear what i meant Smile
Ralph-Marcus
Luke Spadavecchia
Brighton
👌 Thanks Ralph - I get it now - much appreciated
Luke Spadavecchia
Brighton
Hi all,
I aquired a Beolink Video MkII 1615 and connected it up - Unfortunately I can't get it to work. When I connect the 1615 to the Mac via the Lintronic converter I'm just receiving the following code via RS232 once every 5 seconds or so:
<0001915001000240000000055> this translates to "To PC from Lintronic Box via RS232 String - version 00,1 mode 000, trigger 240"
No other commands are transmitted to the Lintronic box, whichever key I hit on the Beo4 (Light/Video/Music) the commands are ignored. The cabling etc is all correct because it works with the 1611 box which has identical datalink pinouts. I think there is some kind of "handshake" expected between the datalink equipped beovision and the 1615, but since I don't own a vintage beovision I can't confirm that.
I think this experiment may be a failure!
Thanks to everyone for their advice so far - All the best
Luke
RaMaBo
near Munich
RaMaBo replied on Tue, Mar 19 2019 1:36 PM
Hi Luke,
sorry to hear that it didn't help to solve your problem.
I just remembered the old Beolink converter 1614. This device was before the 1611, which had the feature to act as an audiomaster if no Video nor Audio Master was connected to the Masterlink System.
The 1614 had the same connections as the 1611 but not the audiomaster function. So this might be a solution if it routes the IR commands from ML to the Datalink pin of the AudioAux connector. I'll have a look whether i have 1614 when i'm home. If so i can check it with ML and the Lintronic box.
Ralph-Marcus
RaMaBo
near Munich
RaMaBo replied on Tue, Mar 19 2019 3:34 PM
Just scrolled back to the  begining of the thread and stumbled over this:
Luke Spadavecchia :
....Here's a basic schematic of what I'm trying to do:
There is now video master in your descrption! This might be the cause of the failed 1615 test..
Also powering up the whole system in a certain sequence might help you.
1. - 1615
2. - BS7000
3. - 1611
Maybe this helps?
Ralph-Marcus
Stefan E
Sweden
Hi Luke,
So its only music (iTunes) you could like to control on your MacMini and also via your BS7000.
An option I was using earlier that worked was to use Beolink / BeoPort PC2 together with linkplayer or any other OSX capable software, perhaps you may not use latest version of OSX.
Stefan
BS3 DVB-HD, BV7-40 MKIII, BC6-26, BC6-23, BV4-50/BS2, BS5, BS9000, BL3500, MLGW, BLGW, PlayMaker, - BS6500, BS4500, LX6000, VX7000, MX5500, VX5000 - Beo6, Beo5, BeoTimex2, Linctonic
Luke Spadavecchia
Brighton
Thanks Stephan, I’ve tried a BeoLink PC2. Unfortunately it will not work with my setup - I believe it needs a later system such as the Beosound 3000
Luke Spadavecchia
Brighton
Hi Ralf - did you have a chance to try a 1614 converter? I’ve found one for sale but I’m holding fire on it until I’m confident it will work! Thanks again for your help
RaMaBo
near Munich
RaMaBo replied on Thu, Mar 21 2019 11:00 AM
Hi Luke,
sorry it was quite late when i came home yesterday. I'll have a look this evening.
Ralph-Marcus
RaMaBo
near Munich
RaMaBo replied on Thu, Mar 21 2019 8:36 PM
Well, at home now Smile
But i don't have a 1614, sorry!
1616 (BL activ) and 1615 BL video collecting dust, and a 1611 connected between ML and BeoSystem 2500.
Thinking about your configuration makes me wonder how you would control the MAC audio? The Beosystem 7000 knows Tape 1, Tape 2, CD and phone as external sources and all inputs  are in the BS7000. There's only one more source group available via the AUX/TV connector: Audio from video devices via ML in your case
The BS700 is in another room you said in the thread opener! How do you transport the audio signal to the AUX/TV connector?
Ralph-Marcus
Page 1 of 2 (26 items) 1 2 Next > | RSS
