Beosystem 3 service manual or hard factory reset instructions
Not Answered This post has 0 verified answers | 13 Replies | 1 Follower
markadams
Silver Member
markadams posted on Sat, Mar 2 2019 6:54 PM
No issue, I found the service manual on the beoworld site. No response required.
I am new to the forum. I have purchased a beovision 4 50 and a beosystem 3 from separate locations. The screen is type 9023, item 1818738, serial 20093591. I would be keen to know what particular model is.
My major issue is that clearly auto detect monitor is off so I can't see the beosystem menu to change things or do a soft reset. I have searched the archive but any reference to service manual doesn't link to a live document. I've searched the service manual page but I can't find beosystem 3. I would like to restore the factory settings of the beosystem so I can introduce the screen anew. I've seen some references to a non beo4 reset but details are lacking.
markadams
Silver Member
It's ok, I found the service manual on the bel world site
markadams
Silver Member
markadams
Silver Member
Dante
Sao Paulo - Brazil
Dante replied on Fri, Jun 7 2019 11:29 PM
I'm having the same problem, but I just can't find the RESET function in my Beoremote One. The only reset I found was Factory Reset which resets the remote itself, not the BS3.
Does anyone know how to find it?
Thanks, Dante.
DMacri
United States
No, sorry I’ve already returned my BR1, but I had use it to reset my BS3 to accept non Navi commands. Once I did that, I was able to program my Beo4 to send the reset command to the BS3 and start up in safe mode. Them I could set the right resolution for my monitor. In my case a projector,
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, and ambio
BEOVOX141
Denmark, West
Silver Member
The reset function is somewhere in the customer service menu (OPTIONS red arrow go) or the service menu (OPTIONS 0 0 go), cant remember witch one...
Dante
Sao Paulo - Brazil
Dante replied on Sun, Jun 9 2019 2:41 AM
I don't have access to the TV menu; that's why I'd like to reset the BS3 using only the Beoremote One.
BEOVOX141
Denmark, West
Silver Member
Did you try the Display 2 output ?  Switch using FORMAT 0.
Try hooking up a PC monitor.
chickenceo
Silver Member
Hello Dante,
Were you able to factory reset the BS3 without on screen menu? My BS3 is showing white noise after the curtain and I cannot pull up the on screen menu with beoremote one.
Many thanks!
Dante:
BL8000, BL10, BL4000, BL2, BL3 (Sold), Beocentre 2, Beosystem 3, LG C8
Dante
Sao Paulo - Brazil
Dante replied on Thu, Nov 21 2019 10:52 PM
I didn't manage to do the factory reset, however, I was lucky enough to find out that the problem was on my HDMI cable.
I was using an ordinary HDMI and after replacing it with a HDMI Ethernet version, the image came out.
chickenceo
Silver Member
which cable? The input HDMI cable or the output DVI-D to HDMI?
Dante:
Dante
Sao Paulo - Brazil
Dante replied on Fri, Nov 22 2019 1:04 AM
The output cable.
As input I'm using AppleTV 3rd gen with a ordinary HDMI; and Chromecast 2, which plugs directly in the HDMI socket.
chickenceo
Silver Member
Thanks! let me try a new cable and finger crossed.Big Smile
Dante:
The output cable.
Page 1 of 1 (14 items) | RSS
