BeoLab 6000 and Yamaha WXC-50 - any advice or alternatives?
Answered (Verified) This post has 1 verified answer | 11 Replies | 1 Follower
Wiggster
Wiggster Confused [*-)] posted on Mon, Feb 18 2019 3:13 PM
Hi All,
I have recently bought some lovely beolab 6000 speakers, and a fantastic beogram 5500 after moving into a new house.
My original intention was to buy the sonos amp when it was released last week, and use this to take advantage of the optical in (TV mounted above the record player), the Aux in (for the beogram) and the beolabs connected as the speakers either side of the TV in addition to all the Sonos spotify/airplay etc.)
I soon found out that active speakers and the sonos amp were not good bed fellows. Originally, the sales assistant in richer sounds recommended the Yamaha WXA-50 - as it had an aux out (RCA) - however, when I connected this up at home, I found that the aux out was fixed to 100% volume... so pretty painful.
I was looking at the WXC-50 which has a pair of RCA pre-outs - would these solve the problem? I notice that the BL 6000 'wake-up' when activated, and other forum posts suggest that the line connection makes a buzzing noise?
1. Is the WXC-50 a good option? Will I be able to use it's volume control to manage the speakers?
2. Is there an alternative set of cables than just the RCA directly into the BL 6000? Only power cables were supplied with the speakers, so don't have any at the moment.
Any advice gratefully received!
Jeff
Peter Pan
Verified by Wiggster
Hallo Wiggster - Here what I found on the subject.
What works great is getting TV audio from Sony Bravia out in the Beolab 18's
via Yamaha WXC-50 pre-amplifier. No "lip-sync" problems and since I have RCV
3000 IR eye on Transmitter 1, I can control the sound level with the TV remote
control alone (does not need to adjust on the preamplifier once set). The Yamaha
has also built-in AirPlay + their own MusicCast system. There is an excellent app
with internet radio, dna access etc. I would have liked to opt for a B&O product,
but there there was no one with digital input and output.
tph
Finland
tph replied on Mon, Feb 18 2019 3:57 PM
Wiggster:
Yes. There is a "preamp / player" switch at the back of the Yamaha unit. When set to "preamp", the level of the RCA outputs will be controlled by the device, allowing you to use your BeoLabs with it.
davidr
Montréal
davidr replied on Mon, Feb 18 2019 8:05 PM
As noted above, the WXC-50 can be set to pre-out (volume controlled).
Also it has a handy 12v trigger output, with the correct adapter cable, you can have triggered "powerlink" to your BL6000s.
Wiggster
Thanks all for the quick and useful responses - will look into the cable with triggers - sounds handy!
will pick up the wxc-50 tomorrow- looking forward to hooking it all up!
Peter Pan
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Hi Jeff,
Yes, you can use the Beolabs directly into the pre-out sockets of the WXC-50, no need for a trigger signal as the speakers can be set to Line mode so that they will turn on automatically when the music plays.  One cable will connect two speakers to the WXC-50:-
https://soundsheavenly.com/line-in-connection/6-30-av-processor-pre-amp-sonos-to-beolab-rca-line-in.html#/2-length-1m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Wiggster
This was so very helpful! Thanks so much for sharing.
Wiggster
I ended up getting the WXC 50, along with a small subwoofer. It works brilliantly - and I can’t notice any lip sync issues with the optical in... although I may have stared at it for too long!
The phone connection in from my beogram 5500 is a bit quieter than the other inputs but think I might just need a better phone pre amp- plenty enough for now!
thanks for all the replies - so helpful!
Cheers- back to listening to those records now!
jeff
Jeff
USA
Silver Member
Jeff replied on Tue, Feb 19 2019 11:14 PM
Hi Jeff, good name there guy! Stick out tongue
The B&O cartridges, especially the MMC series, are lower output than most phono cartridges. I use one of the following as a phono preamp:
https://www.phonopreamps.com/TC-770LCpp.html
This is designed for B&O gear, it not only has more gain, and a variable gain so you can match levels with the other sources (CD, streaming, etc.) but it has a DIN connector on the back as well as RCAs so you don't have to use a DIN to RCA convertor on the Beogram (most aren't factory wired with RCAs). I've used one of these for about 7 years so far with my Beogram 3000 Tangential with MMC2 and love it. Sounds great, plenty of gain to get the Beogram up to the level of the CD and Aux In on my Beosound 9000. Highly recommended, and affordable.
Jeff
Wiggster
That's great! I just ordered this, as there's definitely a marked difference in the volume from the record player...
Jeff
USA
Silver Member
Jeff replied on Wed, Feb 20 2019 4:03 PM
I had the same issue with my setup using a more "traditional" phono preamp, there was a large difference in volume between the LP and the CD, and woe be unto you if you hit the CD button after playing an LP without first turning the volume down!
Hope it works out as well for you as it has for me. Neat little company actually.
Jeff
Wiggster
Just to complete the thread, I can heartily recommend this preamp - I now have amazing quality sound, both from the record player in the lounge with the beolabs and subwoofer, plus all around the house from the Yamaha multiroom. I can die happy!
thanks again to all who gave their time to help!
Page 1 of 1 (12 items) | RSS
