Sticky residual on black parts
Not Answered This post has 0 verified answers | 10 Replies | 0 Followers
Oasis
Oasis posted on Tue, Feb 12 2019 8:21 AM
Just wondering if anyone have any advice on cleaning off sticky residuals that has developed over time on the soft touch black plastic components of Beolab speakers? I was told they don’t come off once that happens...
Hiort
Sweden
ONLINE
Hiort replied on Tue, Feb 12 2019 8:34 AM
There is nothing you can do.
It’s the plastic itself that is degenerating.
Had that problem with a Beocom 2 charging base. Eventually the plastic just cracked.
bidstonhall
Thailand 5560 miles from Struer
It's a nightmare, I have had it on so many pieces, 2 beocom 2 chargers for a start
sadly i am now having trouble with a beosound 6 I received from Evan a year ago, the black plastic parts have started to go sticky, very annoying indeed
Hiort
Sweden
ONLINE
Hiort replied on Tue, Feb 12 2019 10:53 AM
There are some videos on Youtube where they cleaned the sticky thing with alcohol.
Think it all depends on how bad shape it is in.
Link
marexy
marexy replied on Tue, Feb 12 2019 11:21 AM
I just clean it with benzin or isopropanol and than spray it with Plastidip.
iankw
Silver Member
iankw replied on Sat, Jun 6 2020 5:22 PM
I had some tools where the rubber had degenerated to a horrible sticky feel. I used an IPA spray and a bit of elbow grease with a cloth and now they are like new. You could try some rubbing alcohol if you have any cos its basically IPA. (Isopropylalcohol) Not drinkable BTW!
andy_js
Englandshire
I find most IPAs are not drinkable.
George190
Silver Member
Edoardo
San Marino
Edoardo replied on Wed, Nov 17 2021 10:48 AM
I do agree Big Smile
Edoardo
San Marino
Edoardo
San Marino
Hello, I can just tell you mi experience with a Beolab 7.2. it got sticky after some years. According yo a friend of mine, expert in metal treatments and painting, I provided to dismount it from the television (Beovision 7-40), and disassembly it completely. Then, I provided to treat the aluminium shell with nitro thinner, then rubbing it with a cloth, until all the sticky black plastic went away. The black paint that remained on the shell was non perfect, but good, so no further treatment was necessary. So I provided to re-assembly everything, then mounting the loudspeaker on its place. I am very satisfied with it.
Page 1 of 1 (11 items) | RSS
