What's with all the mono-only speakers?
This post has 30 Replies | 2 Followers
beopaul
Posts 79
beopaul Posted: Mon, Feb 4 2019 10:45 PM
I was thinking of getting an A6 speaker, but it's been discontinued. There's all these mono speakers now instead (M3, M5, Beosound 1&2). I don't see that these can be paired for stereo, (though the portable speakers seem to have that capability). Are people giving up on stereo because sitting in the sweet spot is too limiting? Were the all-in-one units just not giving enough separation to be worth it (I know the A9 and BS35 still exist)? What's the story here? I'm a bit hesitant to buy an all-in-one wireless speaker that's only mono.
-- Paul
9 LEE
Eastbourne, UK
Posts 7,148
9 LEE replied on Mon, Feb 4 2019 11:33 PM
I think that as most people just want a 'compact boom box' these days it's rather pointless trying to separate stereo when the drivers are literally a handful of centimetres apart..
Just have one driver and make it bigger, so more boom.
I've probably completely missed the point, Geoff Martin will interject with something technical, and I'll crawl back under my stone again - but that's my thought on it.  :)
trackbeo
Posts 424
trackbeo replied on Mon, Feb 4 2019 11:35 PM
People are giving up on stereo because they are lazy and cheap, and it takes a lot of,... you know,... like,... space?  "Heck, this other cute one still *Plays* *My* *Music*, right?"  Besides, if you are going to buy a tiny speaker and wedge it onto your kitchen counter, in the corner, shoved back echoing between the countertop and the upper cabinets,... well, who the heck *cares*?
Seriously though, it's pretty basic: the difference between no-music vs. having-music, is much much greater than the difference between mono music vs. point-source stereo music vs. separated channels.  And in some places, like the kitchen in my example, arranging stereo for multiple areas is tricky.  People just don't get that they could buy 6 speakers and play them all less loudly, then arrange them for sink, stove, and table stereo images, plus a decent L/R vs. R/L "traveling" image.  Even understanding, they still don't want to bother or don't want to spend the money.  It's just too much trouble, if all you really want, is to whistle while you work.  Apply the same only-slightly-exaggerated scenario to other rooms of the house.  Just grab a speaker, toss it wherever you are.  Lather, rinse, repeat.
The same question gets asked of Sonos, where the Play:1 is cute and compact, vs. the Play:3 and the Play:5 try to do stereo from a single box.  At least with Sonos, the answer seems to be "so just buy one Play:1, and if you don't like mono, buy a second one and pair 'em to stereo."  (That's even true of their Play:5; if you turn it vertical it goes mono, then you add a second unit.)  The Bose Wave Radio is another example of point-source stereo.  B&W Zeppelin, Naim MuSo, same idea.  At least the A6 aimed the speakers slightly outward so it would sound 2-channel at a medium distance.  I have heard all four; all are "just fine."  I happened to like the A6 best.  Does stereo matter?  I dunno...  To me, it only sounds "right", i.e. stereo image w/non-exaggerated bass, if you place them away from the wall, and sit 4 feet away.  But that's just me.  I put 6 ceiling speakers in a kitchen once...  They liked it.  But they also added a Play:3 in the corner of their dining room.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Mon, Feb 4 2019 11:54 PM
Because modern music is so bad...hearing it out of two speakers would be twice as bad.
Jeff
Barry Santini
New York
Posts 523
If you got the space for “good stereo,” then upping to good surround is no biggie. With that done, music becomes background rather than foreground, and imaging less important as the sweet spot is never a place you’ll stay in for long.
trackbeo
Posts 424
Even upgrading to *bad* surround generates a result that (some people think) is perfectly OK:  Have you ever pressed the 5-speaker button on a Bose Lifestyle remote?  It does some processing to generate a Center and pushes some kind of signal into the Left/Right Surrounds.  The rear channels even have their own volume up/down buttons, so it was clearly intended for such "party" use, as it sorta kinda fills a living room with sound(s).
vikinger
Vestri Kirkjubyr, UK
Posts 5,393
Surely a 'proper' stereo system gives you the best of all worlds. Stereo in the sweet spot, and 'surround' or background when you are standing or sitting anywhere else. In small rooms BL3500's can achieve this, and if Masterlinked together you get a smooth sound transition moving room to room.
There's mention of the Bose Wave Radio above. I have a Mk 1, still in regular bedroom use. Updated with Chromecast Audio it’s output is remarkable. Bose never made any special claims about the Wave R. being Hi Fi etc but it does have a remarkable stereo output, including bass, from those plastic waveguides!
Graham
Millemissen
Flensborg, Denmark
Posts 13,522
ONLINE
Jeff:
You could also argue, that the hearing of the slippers and pipe generation is so bad that they need two speakers.
Millemissen
Flensborg, Denmark
Posts 13,522
ONLINE
beopaul:
How often do you sit in the sweet spot, when listening to music/music is on???
I do occasionally, but not always - that is the reason why I have both options at home.
Guy
Buckinghamshire
Posts 2,023
Guy replied on Tue, Feb 5 2019 9:12 AM
I've just purchased a second A2 Active as I am keen to have at least the option of stereo when travelling/outside/in the garage/etc. Often in these environments it's far easier to find the 'sweet spot' for listening rather than in the clutter of home, when I always seem to be moving around and doing other stuff.
Also, I do appreciate good stereo separation in the car -  where let's face it, a significant proportion of many people's listening takes place.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Tue, Feb 5 2019 11:01 AM
Millemissen:
beopaul:
That's why you use B&O speakers with the ALT lenses...the "sweet spot" isn't confined to a spot!
Jeff
Michael
Sweden
Posts 2,482
ONLINE
Michael replied on Tue, Feb 5 2019 11:09 AM
I think people are less trying to replicate music as it was performed in a studio and more trying to make their home comfy and inviting. A smaller speaker thats more flexible in placing and size has perks that a stereo system rarely can provide. Sure a small stereo speaker can somewhat do both but how much stereo separation is there then, and is it worth it? Maybe you want fuller sound instead of directional speakers. A portable speaker is even more inconvenient with stereo since it might be placed in different places with different reflections and so on. Then a mono speaker is beneficial because you can focus on making it sound good, loud and clear and make it as small and convenient as possible. And beautiful.
I listen quite a lot on my small bluetooth speakers that I can walk around with in my home. It works well and the music comes from it. I am not sure that stereo even gives me any benefits at all in most cases. Music played back live is more than stereo too and usually you put a microphone or two, or three on each instrument and mix it down somehow to a mix decided by a technician. Stereo could therefore arguably be pretty faux.
Beolab 50, Beolab 20, Beolab 8000 x 2, Beolab 4000 x 2,
BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9i, BeoPlay H6, EarSet 3i,
BeoVision Avant 55, BeoPlay V1-40,
leosgonewild
Posts 2,092
Guy:
Brings me back to when I had JBL Decade speakers with a dual 10” sub in my golf MK3. It had so much pressure that my heart literally skipped a beat.
I do enjoy critical listening, but nothing beats the bass pressure you feel on your body in a car. Big SmileBig SmileBig Smile
vikinger
Posts 5,393
vikinger replied on Tue, Feb 5 2019 11:18 AM
Jeff:
Millemissen:
beopaul:
Well said! The argument goes full circle! B&O solved a problem with the acoustic lens, but the majority of speaker manufacturers are focussed on cheaper production. I've often thought that we are gradually conditioned to prefer what manufacturers offer....... rather than manufacturers responding to customer demand. The current trend is that stereo is not important......... not a trend that I follow. Of course B&O are trying to follow both trends at the same time, but do they really publicise the ALT lens advantages sufficiently?
Graham
Andrew
Frinton, UK
Posts 860
Andrew replied on Tue, Feb 5 2019 11:27 AM
In my opinion it is two separate things
Mono for background music or entertaining is fine - people managed with it for years and years, and nowadays it sounds great and is portable. Added to the fact that these days people have so many distractions, a mobile phone is not only used for streaming music, but social media, texting etc. etc. etc. so the attention span and actual listening is not that great.
Personally, if I want to listen, sit down, enjoy and really listen to music, I am lucky enough to have a separate room with the speakers set up properly and the room is dedicated to music and books - no streaming and no TV.
Tassos
Athens
Posts 237
Tassos replied on Tue, Feb 5 2019 12:10 PM
Andrew:
+1
Millemissen
Flensborg, Denmark
Posts 13,522
ONLINE
Jeff:
Millemissen:
beopaul:
I love my BL3’s....too!
I’d say - the ‘sweet spot’ is wider, when a speaker uses the acoustic lens technology.
But that won’t solve the problem completely (and you loose some of the defined stage, that you could have without the lens).
It gives you more ‘freedom’ on the couch - better listening positions when more people/family members are listening.
If you move around in a room, a one point/360 degree system might still be the better choice.
It’s nice to have more options - some will need them, others won’t....no religion there.
trackbeo
Posts 424
Millemissen:
Oh cool -- Ohm Walsh -- I feel young again!!!  Just remove the 180-degree "Tufflex transmission block".  (https://ohmspeaker.com/site/assets/files/2440/ohm_walsh_loudspeaker.pdf)  Only problem is then you want to put it in the exact center of your room!  That makes the WAF very low, but your "ancestors" will "go ape" over it... (old movie joke;-)  Amazingly, you can still buy them from Ohm, doing refurbs.  Equally surprising is that Mirage Omni (e.g. https://www.miragespeakers.com/products/om-design/?sku=OMD-5) are still for sale.  At least so their website claims...
TWG
Posts 1,523
TWG replied on Wed, Feb 6 2019 7:22 AM
leosgonewild:
If you want that at home go and get a Klipsch corner horn and just use the bass part as a subwoofer.
I don't know any speaker that has so much power and yes, I would enjoy a live comparison of a Klipsch horn speaker system with the Beolab 90.
Maybe Geoff Martin had that pleasure at work?!
Regarding the topic:
Those bluetooth mono speakers are nice convenience items, especially when on holidays. Beoplay A1 in combination with a high res audio player is great for the kids to listen to their music and fairy tales - and I can put both devices somewhere high enough on a shelf that the little toddlers can't reach them (which prolongs the gadgets live!)
A2 is used for our music at the holiday home.
When traveling I even use a Beoplay A2 or A1 with a loooong cable to get better sound from the Hotel TVs Wink
At home those items are only for the kitchen, bathrooms or the garage when you don't want to install a complete audio system with link speakers in every room.
So yes, there's a place for them, too, but not as a main audio system at home.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Feb 6 2019 2:21 PM
Oddly enough, Klipschhorns don't really go all that low, I seem to recall a LF cutoff of about 35 hz, not a subwoofer level of bass extension. What they do offer is incredible efficiency and lack of problems with underdamping.
It's also interesting how audio has come full circle. In the beginning, was the single point of sound big old radio. Which evolved into mono "hifi" gear. Which evolved into stereo, and now is coming back to mono again. If you can manage even a small pair of speakers with some separation, not even that much, in my opinion it sounds better. Certainly if you're using a more full range system two speakers makes for better bass as two speakers drive the room modes differently, less chance of suckouts or humps in response.
Jeff
Mr 10Percent
So West, Its Now East
Posts 489
TWG:
And that is what it really is...convenience. I’m trying to keep warm presently in bed somewhere where it’s sooooo cold but have a P6 and an Astell & Kern AK70 PDP on my 2 book book shelf. Totally acceptable for casual listening and portability and for the space I’m in. I do 50 - 60% of my music listening with this combo. Does a job where comfort and luxury is sparse.
When on break, I listen to my music on the BL90s. Totally different experience, not only listening to music, but a vastly improved tonal response and importantly, soundstage and imaging adding layers to the experience.
I can understand both view points; the massive space consuming and gravity bending BL90s for an old-school experience, the P6/P2/A1/A2/H8 etc when serious compromise has to be made. They all deliver pleasure equally for what they are and what they do and there is space in the world for all of them.
OldJack
Split
Posts 335
OldJack replied on Wed, Feb 6 2019 3:43 PM
Millemissen:
Ok,thank you Experts ! I am going for a single Beolab 90 Wink
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
moxxey
South West, UK
Posts 5,206
moxxey replied on Wed, Feb 6 2019 5:08 PM
beopaul:
I wouldn't. I own an A9, owned an A6, BeoSound 1 and various BeoPlay speakers (A1, A2, P6 etc) and the A6 was probably the most disappointing. No way near the level of an A9, lacking the vibrancy of the BeoSound 1. Just felt very mid-range to me. A bit 'muddy' sounding.
I'm looking at a BeoSound 2. More compact than the A9, more powerful than the BeoSound 1 and more an all-around sound.
Millemissen
Flensborg, Denmark
Posts 13,522
ONLINE
OldJack:
Millemissen:
Slave or master?
OldJack
Split
Posts 335
OldJack replied on Wed, Feb 6 2019 11:42 PM
Millemissen:
OldJack:
Millemissen:
Slave or master?
Master.Placed in ''sweet corner'',covering 247 degrees of listening area Stick out tongue
radu_cloud
Posts 1
Hope I don't bother by replying to this old thread, but I wonder why nobody mentions one disadvantage of mono: interference. There is interference in stereo too, if the speakers are not widely apart, but it doesn't compare to the interference from inside of the summing circuit which reduces stereo into mono.
You can try a test with Michael Jackson's Jam first seconds - listen to the voice saying "One, two, three..." and what it goes on saying afterwards. Compare the mono scenario with a stereo scenario, even if the stereo scenario is with 2 speakers close to each other, on the kitchen counter, no sweet spot at all. In mono it sounds muffled. In the "kitchen-counter-stereo" it won't sound separated, but still, it won't be that muffled.
The same with many of ABBA's songs. Or other music which has out-of-phase left/right sounds. You don't know which sounds the producer has chosen to be out of phase, it's a lottery. Even if the music still sounds ok-ish in mono, this lottery cutout doesn't seem to me to do justice even to kitchen music.
Stan
Posts 692
Stan replied on Thu, Jun 25 2020 8:56 PM
There have been discussions about this over the years.  One I recall was around the time when the new BS1 first came out, an early user had a favorite song that had an out-of-phase portion where the 2 channels cancelled out in the mono down-mix.  However, it sounded much better on the BS2 which has separate mid-range drivers (pointed away from each other to minimize interference), and they may have tweaked the software to be a bit more intelligent than straight summing the audio channels (I could be making this part up).
The higher range "mono" speakers (Bs2, A9, Edge, Balance) are actually "single point" speakers as they have separate drivers for the stereo channels so out of phase channel interference is less pronounced.
Bottom line, it's all about trade-offs.  Convenience and simplicity vs. sound quality.  B&O has options for both.  Buy what you like.
I use single point speakers in my back yard as the layout doesn't lend itself to a stereo "sweet spot".  A while back I was doing some re-wiring, and I accidentally wired one of the channels opposite on the other.  Sounded worse than a clock radio.
I also prefer the sound of my "mono" BS2 to a pair of BL8000s I have in my office.  How can this be?  I cannot position the BL8000s to create a good sweet spot.  One speaker must be close, and the other far away and adjusting the balance doesn't fix it.  True, there's not sweet spot, but there's more to music than the sweet spot...  where is the sweet spot when you listen to live music?
PaulGiles
Posts 208
PaulGiles replied on Thu, Jun 25 2020 9:24 PM
It seems very limited to me too.
Ok, sell the “mono” speaker but have the facility to stereo pair like Sonos.
E.g. M3 vs Sonos 1
M3 is stuck as single speaker and you cannot switch the Led off, for. Bedroom environment this can be quite bright.
Sonos on the other hand, stereo pair, ability to switch off led.
B&O have stated it is 100% not possible with the M3. A real missed opportunity I think.
Stan
Posts 692
Stan replied on Thu, Jun 25 2020 10:36 PM
PaulGiles:
E.g. M3 vs Sonos 1
Agree.  Although, the led doesn't bother me because my m3 is in my bathroom
Antonius Robin Iriawan
Jakarta, Indonesia
Posts 77
PaulGiles:
E.g. M3 vs Sonos 1
The newer versions of Bang & Olufsen mono speakers have been fitted with stereo pairing. It was only the bluetooth speakers and Beoplay M5 before if I am not wrong. But now, you can visit the Bang & Olufsen website and find out that the new Beosound 1, 2, and even the new Beoplay A9 can be paired stereo.
Unfortunately, the M3 still has no stereo pairing feature
Best Regards, Mit freundlichen Grüßen, 감사합니다
Antonius Robin Iriawan, 로빈 올림
Beosound 35, Beoplay H5, and Beoplay Earset 3i
PaulGiles
Posts 208
PaulGiles replied on Fri, Jun 26 2020 8:47 AM
Yes, just a strange sales “tactic” to not allow stereo pair
Page 1 of 1 (31 items) | RSS
