Problem with 12" 45 rpm vinyl - Beogram 5000 MMC4
Not Answered This post has 0 verified answers | 21 Replies | 1 Follower
Martynka
Martynka posted on Mon, Jan 28 2019 9:46 PM
I have a problem with playing 12 'vinyls at 45 rpm I bought two albums, one 200 g, second 180 g. Both with a playback speed of 45 rpm. Beogram 5000 recognizes them as 33 rpm and I manually switch to 45 rpm.
Unfortunately, the sound is much worse than at 33 It seems that the needle leaps between the grooves. Where is the problem ?? With MMC4 after the retip ?? Maybe I have to try once again to balance arm ??
Help me, my B&O all-knowing colleagues !!!
Beosystem 5000 - (Beomaster 5000, Beocord 5000, Beogram 5000, Beogram CD50, Master Control Panel 5000, Terminal 5000 Remote Controller), Beovox M70, Beogram 5500, Beogram 5005, Beogram 8002, MMC1 - fully refubrished with nude Shibata, MMC2, MMC4 - newly retipped with elliptical,  MMC4 - newly retipped with nude Fine Line, Beosystem 5500 - (Beomaster 5500, Beocord 5500, Beogram 5500, Beogram CD5500, Master Control Panel 5500, Beolink 1000)
Martynka
Martynka replied on Thu, Jan 31 2019 11:13 PM
I lfted the top cover yesterday:
According to the manual, I made all adjustments. I set:
- turntable height
- pick-up height
- pick-up arm paralleism
- adjusting the lever from antiskating while the turntable is working (the tension and loosening of the arm almost has no effect)
I talked with Joseph about this problem and he decided that exchange my retip MMC4 to another (MMC4 with nude diamond like in MMC3)
Søren Mexico
Mexico City
Looks like your transport screws are attached, here mine
Søren Mexico
Mexico City
And who is Joseph ?
Martynka
Martynka replied on Thu, Jan 31 2019 11:47 PM
You see right on photo but transport screws now are loosen . I attached it when I turned the turntable to disassemble. I loosened it when I did regulations too.
My MMC4 is about 15 hours after retip. Retip did Joseph Long aka "Needlestain" from US.
Søren Mexico
Mexico City
I dont know Joseph. but I have done various retips (MMC2-4, SP14 with "Schalplattennadeln" (Axel) in Germany, and bought a SMMC4 from Soundsmith  so maybe you have something with your MMC4, lets see when you get another one
Martynka
Next week I get my Beogram 5500. I will put there this MMC4 to try on linear turntable. After that, regardless of the result, I am sending MMC to exchange.
and maybe faster I buy another one MMC ( I try buy MMC2 )
Martynka
The problem with MMC solved. I sent the cartridge to Joseph, he immediately sent me a new one. Now it sounds perfect on every vinyl There are no problems either with shipping or with exchange. I just recommend retipper, first class !!!!
Page 2 of 2 (22 items) < Previous 1 2 | RSS
