BeoLab 6000 Speakers Problem
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
MeliadMike
MeliadMike posted on Mon, Jan 14 2019 5:01 PM
I have my BeoLab 6000 speakers connected to a non-B&O system so have to use the phono sockets (LINE).
When plugged into power with speaker wire plugged into the phono sockets the Green light comes and stays on and I get serious Hum. I have plugged the power through an Ebtech Hum X and it makes no difference. Removing the speaker wire from the phono socket and the hum disappears and the small light goes to Red.
I have taken a speaker to a far part of the house and plugged it in with no other components to reduce any possible interference and it makes no difference.
Does anyone have any suggestions ?
Andrew
Frinton, UK
Silver Member
Andrew replied on Tue, Jan 15 2019 8:49 AM
Sounds like it is either the lead going into the speaker, the source or it is a loose connection on the phono socket - I have a BL6000 that has a problem with one of it's phono sockets.
MeliadMike
Thanks Andrew. Looks like you might be right. Removed current lead and plugged in a standard "Monster" AV cable and the hum disappeared. I'll splice the AV cable to the speaker wire over the weekend and see if I'm good.....thanks again.....Mike
Page 1 of 1 (3 items) | RSS
