B&O 3D Prints
Answered (Verified) This post has 2 verified answers | 36 Replies | 2 Followers
Christian Leicht
Aarhus, Denmark
Silver Member
Christian Leicht posted on Sun, Jan 13 2019 3:43 PM
If anyone's interested i just added a lot of my own custom B&O 3D prints to my website. They are free to use.
You can find and download them right here: https://leicht.io/projects/3d-models/
Kind Regards,
Christian Leicht
https://leicht.io - B&O Custom Parts & 3D Models
Beobuddy
Utrecht, The Netherlands
Solved by designing a small part and printed with a 0,25mm nozzle.
The journey between designing and finally usiing the printed part can be very satisfying.
Beobuddy
Beobuddy
CDX lid gearwheel:
TWG
TWG replied on Fri, Mar 1 2019 6:15 AM
A very good and helpful thread! Keep going! Thumbs Up
Beobuddy
After several attemps, prototypes, this one comes out as the best. Smooth sliding, original dimensions. Only the small parts at the bottom are made a bit thicker . So, it should better handle the force when sliding.
Beobuddy
All are printed (again) with the 0.25 nozzle to give it the most precise corners etc.
TWG
TWG replied on Sat, Jun 22 2019 8:56 AM
You're doing such good jobs with these 3D spare parts!
Is it possible to make the A9 keychain remote plastic covers in 3D, too?
On a regular basis (every few months) my keys seem to have that masochistic desire to touch concrete floor and everytime my beloved A9 remotes got hit badly. The thin plastic cover breaks exactly in the area of the small screw and can't be fixed.
Orava
Finland
Orava replied on Fri, Jul 5 2019 12:47 PM
Beobuddy:
Result::
Have you file on this? Looks smoother than mine. Well since no pics, Beocenter 9000 CD holder...
Beobuddy
All the models I print and showed are designed by myself.
Page 3 of 3 (37 items) < Previous 1 2 3 | RSS
