BL50 again software update problems - flashing master - nothing happens
Answered (Verified) This post has 1 verified answer | 28 Replies | 1 Follower
Flere
Netherlands
Flere posted on Wed, Jan 9 2019 6:36 PM
It seems B&O has published a new BL50 software version.
So this morning again my BL50 do not work anymore.
The Master is with tweeter up flashing once per second.
Master is not reachable on WAN or LAN.
The Slave powers up, raises the tweeter, start flashing, and after 5 or 10 minutes, gives up and lowers tweeter.
Powering off and on of Master or both does not change anything.
Last time this happend was in July 2018 and it needed a B&O service visit to install the SW with USB key. This solved the problem and I have been a happy BL50 owner since then.
And now it is the same drama again.
Do more people have this problem?
- Flere
smile and enjoy the moment
Flere
Netherlands
Answered (Verified) Flere replied on Thu, Jan 10 2019 6:28 PM
Verified by Flere
Flere:
OK. I got the updated firmware from my B&O dealer.
Installed the software on 2 USB sticks.
De-powered the BL50s.
Put the USB sticks into the BL50s.
Switched power back on.
BL50s did each 2 booting and software installation cycles.
Then all was ok.
I have now music again.
I am happy again.
Smile
Installed version is 2.3.4.6892 and the BL50 say this is up to date.
- Flere
Flere
Netherlands
Flere replied on Wed, Jan 9 2019 6:57 PM
The status light on the Master connection panel:
The NTW status light flashes 1x /second white
The WPL status light flashes 4x /second orange
FYI, I do not use WPL.
The master is DPL cable connected to the Slave, COAX connected to the BlueSound node, optical connected to the Mac Mini.
Network connection is via WIFI.
- Flere
Flere
Netherlands
Flere replied on Wed, Jan 9 2019 7:00 PM
This is of course an unbelievable crappy situation for a 30K euro system.
It is now the second time in 6  months.
It is that when they work they are so beautiful.............
- Flere
Mr 10Percent
So West, Its Now East
Currently away from home = so cant check to see if the BL90 have also received an update too?
I find it surprising that there has been a lot of software/hardware issues with the BL50s. The BL50s and 90 software is I believe almost identical and certain functions are flagged on/off for each model.
I’m guessing that the internal PC processor is too lightweight to handle all the code?? Or there’s other hardware which is problematic.. All conjecture but suprised as the 90s are very stable.
Flere
Netherlands
Flere replied on Wed, Jan 9 2019 7:11 PM
Thanks for the reply.
You know, all these problem so far have prevented my from upgrading from 50 to 90.
All these problems with software and reliability have made me doubt a lot about further increasing my personal financial exposure with B&O products......
- Flere
Flere
Netherlands
Flere replied on Wed, Jan 9 2019 7:12 PM
In the mean time I have connected the master via LAN cable to my LAN.
Makes no difference.
- Flere
Flere
Netherlands
Double post
- Flere
Flere
Netherlands
Flere replied on Wed, Jan 9 2019 7:13 PM
Double post
- Flere
gysse2004
Hellerup
I will follow this, better wait with sw update..
peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Mikipidia
Oh jolly not this again, i better cancel the auto update... iam sorry to hear you got the “bug”
New: Beolab 50's, Beolab 18's, Beovision eclipse, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3.
Mikipedi4 on YouTube
https://www.youtube.com/c/mikipedi4
Old: Beolab 1's, beolab 2, beovision 10-46, overture 2300, beolab 8000's, beolab 4000's, beovision avant 32" etc. etc.
gysse2004
Hellerup
I am 2.3.4.6892, says it’s the newest update. No problems so far.
peter
gysse2004
Hellerup
Ohh, and Wisa connection to Eclipse
Flere
Netherlands
Flere replied on Wed, Jan 9 2019 8:50 PM
Sadly I have no connection anymore, so cannot check the sw version number.
- Flere
Flere
Netherlands
Flere replied on Wed, Jan 9 2019 8:53 PM
Mikipidia:
"not again"
Did you also have had this problem in the past? Am I not the only one?
Just wonderd as nobody else was complaining yet about this in the forum......
- Flere
Mikipidia
I had this the sw version before last. Also that one after that made it impossible to update them anymore over wifi. I had the ticking for a long time, don’t know if you remember/knew. Speakers made a ticking noise for the longest time, it’s almost completely gone now.
I would suggest you factory reset them and see if that helps. It seems they’re stuck in a bootloop.
Page 1 of 2 (29 items) 1 2 Next > | RSS
