Samsung 2019 TV's support AirPlay 2 and iTunes...
Not Answered This post has 0 verified answers | 32 Replies | 2 Followers
jarnim
jarnim posted on Sun, Jan 6 2019 9:32 PM
Pretty interesting:
https://news.samsung.com/us/samsung-smart-tvs-launch-itunes-movies-tv-shows-support-airplay-2-spring-2019/
The market seems to be so brutal that even Apple is apparently abandoning their AppleTV.
Sadly, it seems like this will be exclusively on Samsung for the time being...
mbee
Paris, France
mbee replied on Thu, Jan 10 2019 8:54 PM
andy_js:
You’re wrong. Airplay 2 can stream from the cloud, though I think Apple Music might be the only service to support this right now.
I've never seen such behavior: do you have an example?
I think that if you use Siri on an iDevice to say "play Music X on the HomePod", (where music X is from Apple Music) then the HomePod is able to get its music directly from the cloud, but it's the only device that does this, and this is not Airplay 2.
Sandyb
Sandyb replied on Thu, Jan 10 2019 10:03 PM
Not quite - if you play Apple Music (or even Tidal) using the native Apple TV apps, then they stream directly from the cloud. (So not just the HomePod that acts this way) .And this is using the Apple TV remote, not Siri (which won't work with Tidal of course anyway).
If you ask other Airplay 2 speakers to then join in the music from the Apple TV, it is the Apple TV that shares the stream to the other speakers. So you're phone is not involved, bar the play / pause functional control.
But otherwise you are correct - if you stream to an Airplay device from your phone / tablet, then the chain is cloud - phone - speaker.
From the reports it seems as if the new TV's will act as a receiver / like an AP2 speaker only - and as such the audio from, for example broadcast / cable TV, won't be share-able to other AP2 speakers.
For that you'll need to continue using Network Link-ing - which was the most salient question that the new AP2 TV's raised, at least to me.
ptrv
ptrv replied on Thu, Jan 10 2019 10:16 PM
Thanks for your clarification, Sandyb Smile
Page 3 of 3 (33 items) < Previous 1 2 3 | RSS
