sky hd box
Answered (Not Verified) This post has 0 verified answers | 12 Replies | 0 Followers
malcolm welborn
canary islands
malcolm welborn posted on Thu, Nov 22 2012 9:32 AM
 hi uk beoworld hope someone knows the answer to my problem.
my sky+ hd box packed up  so had to get a new one any way if i use the sky remote tv guide works perfectly no problems. if i use beo4 or my beo5 scroll down the list select the channel i want eg sky sports or sky 1 and it opens in planner  everytime.
anyone know what i need to do, my tv is a beovision 10-40 it has the latest software
at the moment no dealer here hence my question in beoworld
malcolm
Opman
Wilmslow, Cheshire
Answered (Not Verified) Opman replied on Thu, Nov 22 2012 10:22 AM
Suggested by Opman
There has been a new Sky+HD set of codes released for the PUC list in your TV. I can't remember the exact differences but your new box would ideally be used with the latest B&O PUC software.
Opman
a2bur
England
Answered (Not Verified) a2bur replied on Thu, Nov 22 2012 11:03 AM
Suggested by a2bur
I have to hit the go button quickly  twice to select , one press on the go will bring up the planner , even when watching a program one press on the go brings up the planner .
malcolm welborn
canary islands
hi guys thanks for your replies technician downloaded all updates doing twice on go rapidly still defaults to planner.
had reply from denmark sky tv box amstrad drx890-r not in puc list. as this is standard issue for sky+hd in the uk would have thought it would have been added already. have to ask uk or any dealer to request it be listed. thought the uk national office would have a lot of requests for this to be done
oh well keep chasing
malcolm
malcolm welborn
canary islands
denmark states not  listed  dealers need to ask for it to be  listed then can be added by denmark and downloaded,
seems a funny way round
malcolm
david707
Silver Member
Malcolm, get them to put "Thompson SkyHD Mk2" in the PUC. That works fine with the 890/895.
David (BV8-40)
MartinW
Hi Malcolm, which remote are you using? If its a Beo4 does it have a navigation joystick? Sky operation is 10 times easier in navigation mode, you would not get this issue.
malcolm welborn
canary islands
hi guys
ok set box stored thompson hd mark 2,  press menu 1 nothing happens no tv guide or anything. use sky remote brings up tv guide if i use beo4 or beo5 now canscroll through programmes  but imediatly select a channel opens in planner . how would beo4 with navigation tool help. driving me mad as no dealer at present. spain confirm any sky box hd in puc list should work.
 to have 890 listed 500 euros
Help
malcolm
malcolm welborn
canary islands
fingers crossed madrid might be paying for it to be listed, but still intrigued how new beo4 would be better
malcolm
kai
kai replied on Wed, Nov 28 2012 4:29 PM
I had similar problem when I installed a friends skybox what I ended up doing was switching of the sky box holding down back up button on sky at the same time put power lead back in with your hand still on back up button after 20-30 secs you should see three lights on sky box it's now downloading latest software after about 10 mins it should disappear then switch on sky box and hopefully that should be you :)
malcolm welborn
canary islands
many thanks downloaded software again still goes to planner when selecting a channel
hopefully get sorted out
malcolm
MartinW
Hi Malcolm, the reason you are going to the planner is because your TV is sending the Play command to the Sky box. This command is a single press of 'Go' on the Beo4. Normally quickly double clicking Go sends the Select command, which is the one you want - but I have come across many Sky boxes where this just never seems to work. If you put your TV in Navigation mode and use the new Beo4 with navigation button then you solve this completely because you then have a dedicated Select button (pressing the joystick in). Navigation is also much easier - moving the joystick moves the banner or cursor on Sky, whereas pressing the diamond button (like a normal Beo4) does channel up/down, rewind etc. no more having to press Go-Left for rewind etc. you basically get a similar navigation to a Beo5/6, without the custom keys that can be added to the touch screen. It is a huge improvement over the old Beo4 for operating Sky.
malcolm welborn
canary islands
hi martin
many thanks  for the info will get the technician to bring one next week, will keep you posted
malcolm
Page 1 of 1 (13 items) | RSS
