BeoRemote one BT
Not Answered This post has 0 verified answers | 16 Replies | 0 Followers
gysse2004
Hellerup
gysse2004 posted on Tue, Dec 18 2018 7:52 PM
I am in the process of purchasing a BeoVision Eclipse, and wondering if the new remote can both be BT paired with the tv, and send Beo4 command to a bs5 ? , without changing the setup on the remote. Also I have a Nl/ML converter and Mlgw.
best regards
peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Jon
Hampshire, United Kingdom
Jon replied on Tue, Dec 18 2018 8:09 PM
Yep it can - I asked this question before buying mine and you just need to change something over to BeoSound mode to use IR (mine hasn’t arrived yet so not sure about the exact steps, but the dealer showed me it working in person)
gysse2004
Hellerup
The BS5 and Eclipse will be in the same room of cause
gysse2004
Hellerup
Millemissen
Flensborg, Denmark
Sure it can!
’changing the setup on the remote’ would merely mean choosing another product to control....
....which can be a BT or a IR product.
The User Guide of the BROne/bt (du ved hvor man finder dem) should tell you exactly how to.!
P.S. Looking forward to hear about ‘your’ Eclipse, when time has come 😉
Razlaw
Razlaw replied on Tue, Dec 18 2018 10:31 PM
I recently purchased a BeoRemote One BT and for use with a Core via bluetooth and a BV7 and connected BS5 and BS3000 via ir.
To switch between the two modes, the steps are:
Press List
Press up or down arrow to move through items shown in display to get to current product mode.
Arrow right to get to ir and bluetooth product selection, in my case displayed as Beolab 20s (bluetooth) and Beo 4 AV (ir)
Arrow up or down to desired product/mode
Press go.
Razlaw
Razlaw replied on Tue, Dec 18 2018 10:33 PM
Just reread your post and saw that you have a converter and mlgw. I know nothing about those so the steps I described are probably totally wrong. Sorry.
Jon
Jon replied on Tue, Dec 18 2018 10:33 PM
Razlaw:
Press List
Press go.
Ohhh amazing thank you! Mine should be here tomorrow so this saves looking through the manual
Millemissen
Flensborg, Denmark
Jon:
I would advice you to ‘look through’ that manual in any case - in fact you should study it.
The BROne is a complex device - it will help you to understand how to use it.
Razlaw
Razlaw replied on Tue, Dec 18 2018 11:11 PM
You will have to initially set up the remote for use with your devices. I did not read the manual initially and mistakenly set it up using Beo 4 video as source instead of Beo 4 AV.
gysse2004
Hellerup
MM, I always read the manual, just don’t think it was very clear. Hope you understand my question right, I want the remote to simultaneously be BT for the Eclipse, and send ir commands to the BS5, without changing settings in the remote all the time.My dealer told me, this was not possible. Hence the question
peter
1990
1990 replied on Wed, Dec 19 2018 10:24 AM
This is not possible at the moment. Unless you configured your NL/ML Converter in such a way that the sources are integrated with the Eclipse.
I think many users would want a ‘hybrid’ configuration where the TV and the Music button can be linked to different products. E.g. TV in BT-Mode for the Eclipse and it’s sources and Music in IR-Mode. Or in my situation TV=IR and Music = NL.
Maybe we could ask Geoff Martin or MrAndersen to persuade the BeoRemote team to join the forum :)
gysse2004
Hellerup
Thanks 1990, that’s the  clarification I needed. What do you mean about the converter, can it be configured in a way, so that the Eclipse can link to the bs5 ?..my bv11 can easily link to bs5 via the converter now.
Peter
digi
Bremen
digi replied on Wed, Dec 19 2018 3:18 PM
Such a 'hybrid' configuration would be great!!!!
Please B&O make this wish come true SmileGiftSmile
BV 14-55 mit BL 18, BL 8000, BL 2, BeoRemote One-BT, ATV 3; BS 9000 & BS Core & BS 4500 mit BL 12-3, BL 12-2, BeoLink 1000; BeoLine mit BC 2, BC 6000; BS 8; BeoVox CX100; BeoTime (analog), BeoTime (digital); Earphone A8; Beoplay H3 + P2
Jon
Jon replied on Wed, Dec 19 2018 3:34 PM
It just arrived, thanks for the instructions earlier - all sorted for what I want (except can’t find an option for A.TAPE for my BS Century/BS2500, but that’s a story for another thread)
Edit:
Found it - just remembered it got re-named from A.TAPE to A.MEM!
Page 1 of 2 (17 items) 1 2 Next > | RSS
