Troubleshooting NL/ML - ML\MCL setup - 5 rooms
Not Answered This post has 0 verified answers | 26 Replies | 2 Followers
Tarch
Silver Member
Tarch posted on Mon, Dec 17 2018 2:50 AM
Hi all, attempting to get some expensive equipment working again as a present to my father. He has a fairly comprehensive B & O house system here in New Zealand which has:
  1. Cost buckets to purchase and install new about 5 yrs ago
  2. Started humming like there was interference about 1 yr ago (at least)
  3. Stopped producing sound in any room other than lounge about a week ago
From what I can tell there is no longer an NZ agent so I'm trying to troubleshoot what I can.
The setup from what I can tell is:
Room
Speakers
ML/MCL Converter
Controller
Other
Kitchen
2 inset roof speakers
Yes & NL/ML Converter
IR Receiver (cover falling off)
Lounge
2 x wall speakers
1 x subwoofer
Beovision 11
Front Outside
2 x square wall speakers
IR Receiver
Side Outside
IR Receiver
Hallway
IR Receiver
These all work with a Beo4 remote. I have previously had the Bank & Olufsen app working on my Android phone which still recognises:
  1. Kitchen NL/ML converter
  2. Beovision 11 TV
The house Ipad still recognises a "Beosound essence" as a sound output option but I do not know which physical part that is.
The Beovision 11 has Apple TV integrated. Ideally I would like to set this up for him to be able to play spotify on the TV, and have sound in other rooms. As easily as possible for a tech illiterate man. In particular I would like a way to see the volume levels of every room at once. He would quite consistently turn the speakers up to max, not hearing anything, then press play on his iPad.
Where do I start troublehooting this? I have labeled each ML/MCL converter and am trying to identify which controls which room.
1990
1990 replied on Mon, Dec 17 2018 7:09 AM
Wow, this is quite complicated arrangement. Never seen so many NL/ML-Converters in one installation!
I'd recommend downloading the BeoTool-app to check the status of all NL-devices. Maybe you can share some screenshots of the results of the app.
Each NL/ML-Converter has its own ip-address with which you can enter a settings page.
Then some standard questions:
- Has anyone changed the network after installation of the B&O equipment 5 years ago? > Are all converters on the same network? Is the physical network still intact and cabling working correctly? And the cabling from the ML/MCL-converters to the speakers?
- Which app is installed on the house iPad?
Millemissen
Flensborg, Denmark
That table can’t be right.
There is absolutely no use for a NL/ML Converter in a room with a set of speakers (not to speak of 5 of these).
*If so installed, the dealer has made a lot of money there 🙄 Or he somehow had to use an existing homenetwork installation instead of a ML-bus.
Are you sure that you don’t mistake these for the ML/MCL Converter aka BL Passive or the BL Active.
In that setup only one NL/ML Converter would be needed - as a bridge between the BV11 and the (assuming) ML connected rooms with the ir eyes/speakers.
You mention a ‘BS Essence’, but do not show it in the table —- ?
My guess is, that there is one NL/ML Converter and a ML-cable going to the respective ‘linkrooms’.
And it seems, that there is no ML-audiosystem involved (but probably a ML Powerbox instead)
Please clarify - it seems kind of odd to me!
(Could you post a pic of these converters?)
Master123456789
Could there be a ML/NL converter with a gaming adaptor, to make wireless net? So you have wireless masterlink?
I have my self also thinked of that idea.
Carolpa
Millemissen:
a NL/ML converter van also be used as a “BeoLink active” kind of device in a NL setup.
So not strange at all
Carolpa
First check the lan cables and switches and/or router. Maybe a switch doesn’t work anymore.
Then go to your router and check out the ip addresses of the NL/ML converters.
Type one of these IP’s in your browser (be sure your on the same network). Can you access the BLC (= NL/ML converter). Do you have the credentials to login?
Millemissen
Flensborg, Denmark
Carolpa:
Millemissen:
I know = of course!
That is the readon why I wrote”
If so installed, the dealer has made a lot of money there 🙄 Or he somehow had to use an existing homenetwork installation instead of a ML-bus.‘
Which means, if there is not a particular readon for it (e.g. a non-existing ML chain), it would be overkill imo.
Tarch
Silver Member
Tarch replied on Mon, Dec 17 2018 9:51 PM
I must say I still don't know what equipment there is - this was just based on my best guesses. All network equipment for the entire house (excluding speakers and IR receivers) seems to be stored in the lounge cabinet, under the Beovision 11.
There are four black converters which I'm pretty sure said ML/MCL converter. A photo is linked. Each has:
  1. Two grey cables. Each grey cable has a large strand (power?) and a smaller strand (signal?)
  2. A power input
  3. A black cable I think is signal input
In the next cabinet there are four silver, sleek looking boxes with no model name I could see. It looks like this one though that has a rubbish photo and ours are around 10cm high. I took these for NL converters.
I say BeoSound Essence as that is the name of the wifi speaker accessible on the ipad. I don't know if this represents another network device.
I will look to get screenshots from that Beolook app in a few hours
Thanks for looking
Tom
stefan
200 miles from Struer
stefan replied on Mon, Dec 17 2018 10:02 PM
Sounds like an MCL setup updated to Masterlink, then updated to NL. With BV11 and Essence as av sources, an NL-ML converter connected to to 4 BL passives connected to passive wall- and ceiling speakers.
Stefan
stefan
stefan replied on Mon, Dec 17 2018 10:15 PM
Forgot the MCL extra speaker kits....
Stefan
Millemissen
Flensborg, Denmark
stefan:
Stefan
Which comes close to my assumption:
‘...Or he somehow had to use an existing homenetwork installation instead of a ML-bus.‘
Will be hard to sort that out remotely from the forum 😏
Tarch
Silver Member
Tarch replied on Tue, Dec 18 2018 12:18 AM
To keep the clues coming it was a brand new house and a full new installation in 2014. I found the installation invoice but there is literally no detail:
" Computer Equipment, various components. Rack components and terminations. Monitor and cables" - then a phone number with a $ symbol in front.
beoaus
beoaus replied on Tue, Dec 18 2018 3:00 AM
Did you try to turn everything off and then on again?
A friend has a complex, MCL, ML and NL system. On Christmas Eve years ago it all went haywire. Most of the converters were inaccessible in roof cavities. As a last resort I suggested he turn off the circuit breakers and then bring them back on and wait 20 mins. It worked !!
So perhaps worth a try.
Good luck, Beoaus.
Guy
Buckinghamshire
ONLINE
Guy replied on Tue, Dec 18 2018 7:36 AM
stefan:
Stefan
stefan:
Stefan
That would be an interesting setup!  A question: Would these MCL extra speaker kits (assuming that they exist!) then allow independent volume control in each of the 'zones'?
I say this because the Powerlink inputs to the passives are variable (usually with volume).  Do the xtra speaker kits allow the passives to vary their amplification of an already variable signal input?
Hiort
Sweden
Hiort replied on Tue, Dec 18 2018 8:09 AM
The boxes in the linked photo appear to be Beolink Passives. There are cables with analogue DIN sockets connected. Strangely enough there are no Masterlink connected, but there is something connected into the Powerlink socket. Could that be the IR eye in the wrong place?
Page 1 of 2 (27 items) 1 2 Next > | RSS
