For Home Entertainment Via LG’s 2019 Line-Up of OLED and Flagship UHD/LCD WiSA Ready TVs
Click here. - Click here.
LG TV line for March / April, these things get HOT. We write about LG 4K TVs 2019 lineups - HDMI 2.1 - eARC system, - Audio accessories - WiSA. If you have news now, write. Thanks.
Hi OlivierC2) Expected price? From November 2018. Download WiSA PDF - Click here.
Millemissen: ‘Hook the LG up the Aux input of the BS9000‘’ How do you do that?
How do you do that?
Trolling again,- are we?
If you apply a bit of mental resources you can properly work it out based on the pictures of the connection panel Peter has been binge posting for weeks!
Or not...
Binge watching LG stuff can cause mental illness 😲
Do you mean that thingy called OUT audio/hp?
Did you try that out - and would you (still) recomment using that for an everyday working connection to the A.Aux-in of the 9000?
Hmmm... not sure why you would ignore the obvious solution i.e the digital out. The insurmountable problem fixed,- cost 100dkr!
How difficult was that? I know,- you are welcome
Hi EgonOlsen
Now, BEOVOX141 and Millemissen have written a lot about connecting your BeoSoundt 9000 for a LG C9 TV. I want to think it can be done like that. Analog stereo pre-out. Can be operatedwith Beo4. It will also be possible to volume control with Beo4.
https://www.flatpanelshd.com/news.php?subaction=showfull&id=1557385354
Caine Thanatos - So ... how is the testing going ? :)
This setting is only available for internal TV speaker. Did you know that.
LG C9 2019 OLED TV review: Another year, another picture champ Its a winner. - Click here.
The Struer company should make a separate unit as to the Eclipse.They don't do that ... yet then ... so until then something else needs to be done.
Overview: LG 2019 TV. 09 May 2019. Flatpanels.
https://www.flatpanels.dk/artikel.php?subaction=showfull&id=1557384895
Use Google translate.
There are also alternatives, though some people complain that their remote controls do not work on this solution.
Ouch! So that means having the Moment AND Transmitter 1 means I can only have speakers WISA-paired with one and not another? Well that is a bit dissapointing.
AnalogPlanet:Ouch! So that means having the Moment AND Transmitter 1 means I can only have speakers WISA-paired with one and not another?
BS Moment, BS Core, BS Ouverture, BG 4002, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
@ AnalogPlanet
Yes you can use both wireless and cable connection, from BeoLab Transmitter 1.
Guide-BeoLab-Transmitter-1.
https://beoprime.com/media/pdf/6c/88/d1/Guide-BeoLab-Transmitter-1-25870e66de005f.pdf
Thank you gentlemen, I guess with all that said I prefer to have Beolab Transmitter 1 rather than a WISA dongle because then I can also connect the Moment into it and utilize BL17s for both TV and music.
I would still prefer, of course to have a B&O TV and how do I solve the Moment problem in that case? I connect it to TV and let TV be the main/only WISA "transmitter" to loudspeakers?
If I have understood what you mean.
AnalogPlanet:because then I can also connect the Moment into it and utilize BL17s for both TV and music.
