For Home Entertainment Via LG’s 2019 Line-Up of OLED and Flagship UHD/LCD WiSA Ready TVs
Click here. - Click here.
LG TV line for March / April, these things get HOT. We write about LG 4K TVs 2019 lineups - HDMI 2.1 - eARC system, - Audio accessories - WiSA. If you have news now, write. Thanks.
No - that is something that you get when you pay for the B&O solution.
In the above case, I wouldn’t really know what to enter on a B&O tv.....it is Penta, yes - but not really, because there is the ICE Power module in between.
Another problem would be to enter the right distance in the setup . Must it be the distance to the Receiver 1/s or to the actual speaker/s???
Good point, actually! I guess no other way but to enter one value, listen to the setup and then enter the other and listen again. Whichever sounds better and more natural should be the right one.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, and ambio
@DMicri
Obviously Peter Pan did not understand your question.
As far as I know, there is only a very basic setup procedure with the WiSA Ready implementation in the LG’s.
We will know for sure, when the first people try it out.
It surely will not be anything that you can compare with a fullblowwn audio processor, like the one in the B&O WiSA-tv’s.
However some (maybe even many) people will be content with that.....they then have nice looking speakers along with a ‘cheap’ OLED screen in their livingroom 😉
Most people don’t care for or notice the suble things a quality audio processing may add to the mix.
But - again....let us see, when the results with the first setups with WiSA BeoLabs will come.
1: don’t know exactly - but I guess with launch of the 2019 LG/OLED’s.
2: no idea, but not that expensive, if I remember correct.
3: You can only connect this dongle (means use with) a tv, that is WiSA Ready enabled.
Means there must be a special software on the tv (like with the 2019 LG’s) in order for this to work.
There is no way what so ever that this could work in a B&O tv.
Peter Pan: Now Millemissen has been negative right from the start. Remember this is an alternative when B&O has sold their last BeoVision TV.
Maybe you should answer the question from DMacri instead of repeating what you have written a hundred times already....
.....or just wait for more information, when the 2019/LG’s are rhere.
