For Home Entertainment Via LG’s 2019 Line-Up of OLED and Flagship UHD/LCD WiSA Ready TVs
Click here. - Click here.
LG TV line for March / April, these things get HOT. We write about LG 4K TVs 2019 lineups - HDMI 2.1 - eARC system, - Audio accessories - WiSA. If you have news now, write. Thanks.
poodleboy: Millemissen: Sandyb: Less of an issue for the C,E,G,W series I guess, but still not perfect. The only perfect thing would be to have a Sound Center, that - as we know it - can mix and match wired and wireles/WiSA outputs... ....or an updated BV Eclipse 😉 After that comes the big question: will people want to pay the price for that? MM Forget the TV and the long-term value will be OK, but add reliable sound-sync capability and mounting solutions. I think this is the best solution for Customers AND B&O. It seems so logical and possible if B&O even want to be in that business anymore?
Indeed, and interesting that its not quite as obvious from forum members that their first choice is actually a new BV, but more the sound centre the solution that you allude to.
Compared to all the back and forth when the Eclipse came out, I do think there has been a shift / general acceptance that the BV value proposition is harder for many to justify (more so than in the past).
Much as I've said I'd like a new BV, part of that is symbolic. And if I move up to a 77 inch OLED (next likely move), I can't possibly imagine buying a 77 B&O OLED.
Sandyb: Much as I've said I'd like a new BV, part of that is symbolic. And if I move up to a 77 inch OLED (next likely move), I can't possibly imagine buying a 77 B&O OLED.
I wonder how much you (and others) are willing to ‘compromise’ in terms of usability (reada Beoremote for all functions...), integration in NL, design etc just to get a (less expensive) screen part that you could swap every second year or so?
Millemissen: Sandyb: Much as I've said I'd like a new BV, part of that is symbolic. And if I move up to a 77 inch OLED (next likely move), I can't possibly imagine buying a 77 B&O OLED. I wonder how much you (and others) are willing to ‘compromise’ in terms of usability (reada Beoremote for all functions...), integration in NL, design etc just to get a (less expensive) screen part that you could swap every second year or so? MM
That is indeed a fair point, as often words and actions don't exactly correspond.
I don't underestimate usability at all.
As and when I change my setup - I suspect I'll only keep my BL speakers, and use something like the new Linn Selekt DSM (which is due to have surround sound added, and 5.1 is enough for me). Subject to how it behaves, the compromise in usability may be offset by having a better music experience, it being a very high end streamer / DAC, and Roon capable, which is something I'm keen to fully explore (subject to cost).
The 3rd party TV remote will be able to do the basics with Apple TVs / Blu-Rays.
So there's plusses and minuses.
Multi-room TV audio is the only permanent loss - and could still swing me back towards a B&O heart.
But no hurry, am happy to see what comes out.
So....I can conclude that you are willing to compromise.
According to your above post - so much that there is no B&O left at all!
