Avant 55 HDMI 1 not working.
Answered (Verified) This post has 1 verified answer | 12 Replies | 1 Follower
Jaymorgan25
Jaymorgan25 posted on Fri, Dec 7 2018 6:50 PM
Hello.
Having just upgraded to Sky Q, I was trying to install using HDMI 1 so we can use 4K, however I’m not having any luck. The TV was installed by B&O, and they only used HDMI ports 2, 3 and 4.
No matter what I plug into HDMI 1 I get no picture.
Any ideas?
Thank you.
Jaymorgan25
Verified by Jaymorgan25
Got it working.
All HDMI sockets failed in the end, but I gave the TV 5 minutes unplugged and everything came back to life.
Pat
Pat replied on Fri, Dec 7 2018 8:43 PM
Try 8 instead 10 mbits
Jaymorgan25
I can’t get that far.
Works on HDMI 2, but won’t go 4K as not a supported port.
If if I plug into HDMI 1, I just get a black screen. I can’t change the res.
Pat
Pat replied on Fri, Dec 7 2018 10:49 PM
8/10 mbits setting is in the Sky Q box itself - make sure that the HDMI lead is the correct one.
TV doesn’t accept 10 mbits, it has to be 8.
Aussie Michael
Melbourne, AU
Pat:
Try changing the settings on the Sky box whilst it is in HDMI 2 then plug in to HDMI 1
If you haven’t used HDMI 1 before it will detect a new connection and ask you to set it up.
This can also be done by the menu on the Avant too. But the key is to change it to 8. And as you can see it on HDMI 2 as non 4 K then try that.
But I thought 1-4 do 4 K since that update a while back. Will have to check the FAQs
Jaymorgan25
Thanks, but can’t change to 8 bit until the Sky box recognises that it is plugged into a 4k output, but when I do plug it in, to a 4K output I just get a black screen.
The only res settings I get currently are up to 1080p
Jaymorgan25
Jaymorgan25
Jaymorgan25
Got it working.
Millemissen
Flensborg, Denmark
Aussie Michael:
Jaymorgan25
They are all 4K, but only HDMI1 has HDCP 2.2, which Sky Q needs. Thanks.
Aussie Michael
Melbourne, AU
Millemissen:
Thanks. That’s the one.
Millemissen
Flensborg, Denmark
Yes - glad you saw it.....the picture is gone now!   Why, I don’t know?
Page 1 of 1 (13 items) | RSS
