Beovision Eclipse - Software bug in latest update (2.3.xx) when swifting audio sources from Deezer to "music" DLNA
Not Answered This post has 0 verified answers | 25 Replies | 3 Followers
Sweden
Martin posted on Thu, Nov 29 2018 3:42 PM
After yesterdays softwareupdate for my Beovision Eclipse soundcenter (software 2.3.xxxx) with Airplay 2, it has arrived a software bug which is very frustrating.
The software-bug appears as follows:
If you start the Eclipse soundcenter with Deezer (thru the B&O app) or Music (DLNA-content), the Bang&Olufsen APP loses the contact with the soundcenter when you switch to another music source. So if You start the TV with Deezer, everything works perfect. But when you switch to Music (DLNA content) the B&O-app loses the contact with soundcenter and there is no cover-art, no time-mark of the song playing and no possibililty to put the music to "pause". If You after this switch back to Deezer, everything works perfect.
If You start the soundcenter with Music-source (DLNA-content), everything works perfect. BUT if you switch to Deezer the same problem occurs as described before (no coverart, no time-mark, no possibility to pause the music).
If you make a "play-list" in the B&O-app and this playlilst has content from both Deezer and music (DLNA-content) the first source that is playing works perfect. When the TV switches to content from DLNA (Music) then the contact between the soundcenter and B&O-app will not work.
Please forward this complaint to your software-developer and make a fix as soon as possible. The last software 2.2.xxxxx before the Airplay2-software worked perfect.
Best Regards
Martin Ström
SWEDEN
Beovision Eclipse 65 with floorstand (from STB Brackets), Beolab 5 front (sw 3.30a), Beolab 3 rear, 2xBeoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K
Sweden
Hi Tomas,
When do You expect the software fix ready regarding the bug I mentioned above for the Eclipse?
Best Regards
SWEDEN
MrAndersen
Hi Martin
The bug is currently being investigated, but I have no ETA on a solution yet.
Br
Thomas
w5bno123
London
Chris Townsend:
Thanks, I’ve no idea how to do it but I’ll crack on. Cheers Beovision Eclipse, Beolit 15, Beoplay A2, H6/H2, Form 2, Beoplay A3, Beovision 5-42 connected to a DVD1
Go to each source input HDMI A-D and at the bottom of the menu you’ll see HDMI control. In your Sky Q box go to Audio Visual Settings and switch off HDMI control.
Chris Townsend
Badsey, UK
Thank you very muchYes - thumbs up
MrAndersen
The bug has been identified and we are working on solution. Test version is expected next week and I will keep you posted on when the fix is going to roll out.
/Thomas
Sweden
Hi Tomas,
Great. Looking forward to get the fix before christmasSmile
Best Regards
mr_anders_son
sweden
New software out tonight!
BeoVision Eclipse 55"...BeoLab 18 as FRONT....BeoLab 4000 as REAR....BL19 SUB....BV5 HD....Beoplay V1-40....BC6-26....Beosound 9000....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H8....H6 90´s Rose Gold edt....Form 1....U70...
Sweden
Martin replied on Wed, Dec 12 2018 4:56 AM
Hi Tomas,
Great work! I have already tried the new software and everything works perfect.
You made the fix very fast😊.
I wish you and the team at B&O a Merry Christmas
Thanks again that you responded so fast on the Eclipse software-bug.
Best Regards
Sweden
tigerisak
No new SW update for me.
MrAndersen
Hi all
This is only out for beta users but will be rolled out to everyone once we have verified. Credit goes to the vision team for moving fast on this, I'm only the messenger :)
I hope we will have it out to everyone soon.
Thank you for your patience
Thomas
Aussie Michael
Melbourne, AU
MrAndersen:
Hi all
Thomas
Well done vision team
Page 2 of 2 (26 items) < Previous 1 2 | RSS
