Beosound 9000 connection to Beomaster 8000?
This post has 2 Replies | 2 Followers
Howzit
Posts 94
Howzit Posted: Fri, Nov 16 2018 8:44 AM
Iv trued searching, but I can’t seem to find any solutions of connecting a Beosound 9000 CD player, to a Beomaster 8000 amp.
The Beosound has a digital and Powerlink out.
Maybe a digital to RCA converter? I believe the Beomaster 8000 has RCA in.
Or is there a powerlink to Din cable?
Beolab 9 | Beolab 8000 | Beolab 6000 | Beolab 2 | Beolab 3 | Beosound 9000 | Beoplay A9 | Beomaster 8000 | Beovox M75, / S75, / S45.2
Peter
Siemianowice Sl., Poland
Posts 107
Peter replied on Fri, Nov 16 2018 9:42 AM
Beosound has also DIN out so you can connect it to Beomaster via DIN-RCA cable
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,095
Hi Howzit,
Which speakers are you using and which product are they connected to please?  Do you have other rooms connected to the 9000 by Masterlink, or a TV in the same room please?  Are both products in the same room (ie. within remote control range)?
This will help us to understand the best way to get everything connected, so that we can give you the best advice.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (3 items) | RSS
