Beosound Shape +ML + BEO4
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
Silou
Switzerland
ONLINE
Silou posted on Fri, Nov 9 2018 2:24 PM
Hi
Is it possible to integrate a BS Shape with ML ?
Does it work with Beo4?
Millemissen
Flensborg, Denmark
Beo4 - Yes, if you have an ir-eye connected to the Core of the Shape.
Integration with ML - For this you will need a NL/ML Converter.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Hi Silou,
Yes, there is also another option - for a basic (4 speaker tiles plus one amplifier) Shape, you can use this as a normal set of stereo speakers.  You just need to connect a Core to set up the speakers, then the Core can be removed and you can link the Shape amplifier directly to a Beolink Active to work as an integral part of an ML system.
Please feel free to get in touch via my sponsor link below if you would like more details of the cables for this option.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Silou
Switzerland
ONLINE
Silou replied on Tue, Sep 17 2019 11:36 AM
Thanks Steve,
If I understood correctl. Once setup is done you can remove the core, plug RJ45 from speaker into Beolink active DIN connector's. Of course ML into ML network! And using IR eye to control souce/volume,... on the Shape.
Am I right ?
Hi Silou,
Yes, that is correct!
Steve.
Page 1 of 1 (5 items) | RSS
