BV7-40
Not Answered This post has 0 verified answers | 2 Replies | 0 Followers
Langleyav
Windsor UK
Silver Member
Langleyav posted on Fri, Nov 2 2018 10:47 AM
I have moved my BV7-40 and now need to reprogram the end stops on the motorized stand. What is the procedure to do this.
Ron
trackbeo
Silver Member
See:  https://www.bnoservice.nl/manuals/beovision7MK.pdf
, page 28.  This might also be in your "Getting Started" manual because it was part of your initial setup.  After the initial setup was done once, the menu item "Stand Adjustment", which is what you want -- gets hidden *inside* the "Stand Positions" menu (which itself, until setup was finished, remained invisible)?
Langleyav
Windsor UK
Silver Member
Done!!
Many thanks, I found the "menu within the menu" option.
Ron
Page 1 of 1 (3 items) | RSS
