Transportation of BV 7-55
Not Answered This post has 0 verified answers | 6 Replies | 1 Follower
MartinRK
MartinRK posted on Wed, Oct 31 2018 9:02 PM
I have just bought a BV 7 55 MK II from 2013 Smile
I probably have to transport it in the trunk of my car. Is it okay to transport it lying down or should it stand up?
If lying down, should it be on the backside or the front side (screen down)?
Guy
Shropshire
Guy replied on Wed, Oct 31 2018 9:42 PM
The preferred method is standing up, but personally I'd be happy transporting an LCD TV flat if carefully supported and padded.  Watch out for potholes!
Millemissen
Flensborg, Denmark
MartinRK:
I’d have it on the backside - and beware of the blu ray player-part, that it won’t get damaged
The Beonic Man
Bristol
It's fine if you're careful; it's only plasma screens that need to be upright when transported.
Current products: BV11-46, BV8-32, V1-32, A1
MartinRK
Thanks for the advises
I will give it a go, and put it on the backside, carefully supported by all kind of soft materials...
beolion
Silver Member
Yes. I did the same and it worked fine.
Just be careful with the built in bluray player tray.
MartinRK
I will for sure
Page 1 of 1 (7 items) | RSS
