Dear all,
I have the beosound 9000 as main room and Beolink active connecting beolab 3 as link room; I want to add the NL/ML converter to make the whole enviornment NetworkLink ready;
But I really want to see the screenshot of B&O APP with the beosound 9000 and Beolink active (beolab3) or similar old products (maybe beosound 3000) in the APP - I think this is very magic! I trust we can almost control everything to the beosound 9000 and the beolink active.Can anybody share such screenshot for me?
After I have such impression, I think I will buy the NL/ML converter. Thanks!
Daniel
BeoNut since '75
danielshen:Hi elephant, I am waiting your screenshot of BO APP configuration. And one more thing: to add the old product like beosound9000, we do that in the NL/ML web config page or BO App?
Hi Daniel
You won’t be able to see a picture of your BS9000 within the Bang & Olufsen app... you can give it any name you want, but the picture will always be of the “ugly” converter you can see on elephants screenshots
That means that you can’t see all your Masterlink products and control them separately within the app... In many way you can look at the converter as an “link room” products that can play the sources from your mainroom Masterlink system and all the NL sources in your house
Furthermore you can also link the NL products into your Masterlink system
Søren
Soren,
In your view, then my beosound 9000 and old beolink active - baolab 3 in total will be viewed as one single item: The converter. I think that is your suggestion, right?
danielshen: Soren, In your view, then my beosound 9000 and old beolink active - baolab 3 in total will be viewed as one single item: The converter. I think that is your suggestion, right?
That is correct. Only the picture of the NL/ML converter will be shown in the app.
That is the way it works.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Library: A6, Beocom 6000 Bedroom: M5 Office: Beocom 2 Travel: Beoplay E8 2.0, Beoplay P2
Hiort: That is the way it works.
At least untill the app-makers maybe at some point decide for the possibility of placing your own/other pictures there.
Hiort:That is correct. Only the picture of the NL/ML converter will be shown in the app. That is the way it works.
Soren:That means that you can’t see all your Masterlink products and control them separately within the app... In many way you can look at the converter as an “link room” products that can play the sources from your mainroom Masterlink system and all the NL sources in your house
