beosound core standby automatically?
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
danielshen
danielshen posted on Mon, Oct 29 2018 1:26 AM
Dear all,
I connect my beosound core with lab5 or lab3. I always use the Airplay to stream music from my music APP to beosound core. When I push Pause button in the APP, the music in beosound core is stopped; However, I notice the beolab speaker is always on (in green light).
Any way can we set the beosound core automatically standby time?
Thanks for input!
Daniel
Millemissen
Flensborg, Denmark
Not that I know of - you’re just pausing the stream.
If you disconnect the Core from the AirPlay stream, it should go into standby after a while.
Other solution is to use the standby icon in the upper right corner of the (Core) product screen.
elephant
AU
These are my Core’s configuration settings, I think it is the first that will help:
BeoNut since '75
Aussie Michael
Melbourne, AU
I had this when I used to use the BL4 PC
I did the opposite of what they recommended. I think it was either on or off (trying to remember)
The manual said if line in on will always stay on but it didn’t.
What settings do you have set on your lab 3s? Ie left right or line ?
elephant
AU
elephant replied on Tue, Oct 30 2018 10:46 AM
Left and Right as they are PL attached
BeoNut since '75
Page 1 of 1 (5 items) | RSS
