Beosound Moment jukebox (tablet) died
Not Answered This post has 0 verified answers | 6 Replies | 1 Follower
Fansastic
The Netherlands
Fansastic posted on Thu, Oct 25 2018 8:38 PM
Dear members,
Does anyone have experienced same issues with the Moment jukebox?
The tablet seems out of order suddenly. No response at all, as if the battery died. Hard reset with pin did not work and even after day of charging time, no response.
The sound hart works fine, as I can play music through the Moment by using the app.
Thanks for any guidance on this matter.
Best regards
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 -  H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
Hiort
Sweden
Hiort replied on Fri, Oct 26 2018 8:55 AM
Fansastic:
Dear members,
Best regards
There are few post with similar problems.
Only solution is to have B&O deal with it, I think.
Fansastic
The Netherlands
Thanks, couldn’t find the other posts but remembered that the tablet could die out of the blue. Shall bring the tablet back to dealer, 3.5years old, hope they can repair it.
Hiort
Sweden
Hiort replied on Fri, Oct 26 2018 12:18 PM
Fingers crossed. I find it nicer to browse for music using the tablet, rather than using the app on the phone.
Fiddle with the phone enough anyway Smile
Keep us updated on what B&O says.
Fansastic
The Netherlands
Finally my jukebox repaired, the PCB motherboard died. With €435 not really cheap but then again, use of the jukebox as wooden tray only seems not logical either.
One question for the Moment owners. I now have no more click sounds when using the keypad, as far as I recall there were clicks when typing, same clicks when you operate the sound wheel on both sides. Can’t find any setting for it. Please share your thoughts with me.
PeterBOBP
Fansastic:
great that you have it back. I have never had clicks while using the screen. and i do not know of a setting. then again... I might not know everything.
Fansastic
The Netherlands
Thanks for the feedback, I’m doubting my memory and asume if you do not have it, all is normal again!
And after a few weeks without the moment, I realise how much pleasure the Moment gives me for a complete B&O experience. There is no substitute for the touch and looks! So sad that there will be no successor of the Moment.
Page 1 of 1 (7 items) | RSS
