Beolab penta mk3
Answered (Verified) This post has 3 verified answers | 64 Replies | 4 Followers
Andreasi995
Andreasi995 posted on Sat, Nov 17 2012 8:31 PM
I have a beolab penta mk 3 from year 2000.That means the last produced model. They sound wonderful. By moving between to cities in Norway i had to deconnect the loudspeaker from the receiver. In that case i forgot to sign the plus and the minus wire. By reconnecting the base(receiver) to the penta loudspeaker i have a problem. Both wires are grey. I can no long see the different between the plus and minus wire. Can somebody out there help me out of this problem? Pag .
Leslie
the Netherlands City
Silver Member
Answered (Verified) Leslie replied on Sat, Nov 17 2012 8:44 PM
Verified by Andreasi995
Both wires a grey but if you take a close look then you will see one wire has a stripe at the side (right wire on the picture). That should be the plus!
Brengen & Ophalen
Leslie
Silver Member
Answered (Verified) Leslie replied on Mon, Nov 19 2012 7:38 PM
Try Youtube, enough video's to look at!
Brengen & Ophalen
Beobuddy
Utrecht, The Netherlands
I've bought several rings from Good Hifi for several different speakers. But not for the penta. (bought them, didn't use them)
With all my respect and in my humble opinion are these rings not suitable enough. But you already know this and it has already been discussed in the workbench section.
But for the time being...
Stereomensch
BO:
I recapped, two pair of Pentas. The crossovers are slightly different from speakers with serial 04771089.
Part list for speakers prior to 04771089:
Filter Nr uF V %
Woofer & Tweeter C6: 0,68 35 10%
Midrange C6: 0,68 35 10%
Midrange C7: 0,68 35 10%
Woofer & Tweeter C4: 2,2 100 10%
Midrange C4: 3,3 100 10%
Woofer & Tweeter C5: 3,9 100 10%
Midrange C2: 8,2 35 10%
Midrange C5: 10 35 10%
Midrange C1: 22 35 10%
Midrange C8: 22 35 10%
Woofer & Tweeter C3: 47 35 10%
Woofer & Tweeter C1: 68 35 10%
Midrange C3: 82 35 15%
Woofer & Tweeter C2: 220 35 20%
Part list for speakers from 04771089 and forward.
Filter Nr uF V %
Woofer & Tweeter C9 0,68 35 10%
Woofer & Tweeter C10 0,68 35 10%
Woofer & Tweeter C8: 1 100 10%
Midrange C4: 3,9 100 10%
Woofer & Tweeter C7: 5,6 35 10%
Midrange C5: 8,2 35 10%
Midrange C1: 27 35 10%
Woofer & Tweeter C3: 68 35 10%
Midrange C3: 68 35 15%
Can anyone tell me if the Mk3 sound different. I've noticed, that the MK 3 uses a different tweeter than older Pentas. The dome is made of textil.
Thank you very much in advance.
Regars Chris
Stereomensch
Can anyone comment on this topic?
I have a pair of Beolab Mk3 Pentas. Some penta lovers claim, their sound is veilled.
I have the ones with the textile seas tweeter. The sound is absolutely not veilled, it's precise, clear and excellent for voices.
Is it possible, that B&O has updated the crossover and changed the sound of the pentas in the late ninetees or early 2000?
Thanks a lot.
Regards Chris
bramble
Guys ..what is the best thing for cleaning the metal work on this type of speaker
Rgds
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
leosgonewild
Helsinki, Finland
Stereomensch:
Thanks a lot.
Regards Chris
Mk3 had a small change in the crossover.
Stereomensch
So, do the mk3 have a different sound?
They do use a different tweeter and have a completly differernt crossover. Has anyone ever made a comparison between a pair of Pentas from 1988 and 2000?
Page 5 of 5 (65 items) < Previous 1 2 3 4 5 | RSS
