BeoRemote 1 and NOT having radio as default 1st music source?
Answered (Not Verified) This post has 0 verified answers | 2 Replies | 1 Follower
kmspurway
kmspurway posted on Fri, Oct 12 2018 2:02 PM
hello all
I have a BeoRemote 1 Infra Red remote in beo4 mode for a link room - to control a ml beolab 3500. Works well enough but there doesn't seem to be any way to NOT have RADIO as the first / default music source chosen and displayed.
This means that I always have to then select CD or A.MEM on the remote after the radio is started on the main system......
My dealer couldn't seem to even remove Radio as a source - even when unticking it as a source on the remote or re-order the sources so that CD was first one shown
Any ideas / solutions gratefully received
thanks
Luke Spadavecchia
Brighton
Hi there,
You should be able to change that behaviour through the "list" menu as follows:
List > Settings > Advanced > Buttons > Music
Select "None" and you should get the behaviour you want. Alternatively you could choose another source to start on the Music button press. Same applies for video.
Removing the Radio source is really easy too:
List > Settings > Music Sources > Show
Just choose radio and the tick next to the source name will disappear - done!
Luke Spadavecchia
Brighton
Hi there,
I tried to post an answer on Friday, but it seems to have been lost in the ether!
In order to change the default behaviour of the Music key you need to go to
Select the "None" option. Alternatively you could select a different source to play automatically when you hit the Music Key
To remove the Radio option from the source list you should navigate to
Scroll down to Radio and hit select. The little tick will disappear from next to the Radio source and it will no longer show up in the source list under Music.
Hope that helps
Luke
Page 1 of 1 (3 items) | RSS
