Beovox M70... one more time.
Answered (Verified) This post has 1 verified answer | 63 Replies | 3 Followers
Martynka
Martynka posted on Sun, Oct 7 2018 11:29 PM
Hey,
Thread about M70 began here: https://forum.beoworld.org/forums/t/34886.aspx  . To not mix in threads I decided to put it here.
I bought my Beovox M70 , I did not expect much from the state though they played nice. After buying and the first hours in the house spent listening, I decided to look at them more. They are from one pair (matching serial numbers)
The boxes are not damaged :
Speakers and suspensions look good without abrasions, dents and holes in the paper:
The grilles are whole and not broken, although they have small abrasions on one:
and inside....
Crossovers - no repairs, no visible signs of damage, both the same:
SEAS woofers looks like new, with no problem with terminals:
The same with Peerless uniphase - without problem with magnets.
Now, after these few photos I have questions:
- whether recap is necessary in crossovers ??
- is there any canvas that was covered with grills M70 ?? I only have a new stretchy acoustic material, in Infinity it looked like the original but here it is different and I do not know what the final effect will be.
- whether the acoustic parameters of the box do not change after the insertion of modern cable terminals with latches or screws?
- how to mount the grills, now they are fastened with self-adhesive Velcro, but you can see it and it is not perfect ??
Beosystem 5000 - (Beomaster 5000, Beocord 5000, Beogram 5000, Beogram CD50, Master Control Panel 5000, Terminal 5000 Remote Controller), Beovox M70, Beogram 5500, Beogram 5005, Beogram 8002, MMC1 - fully refubrished with nude Shibata, MMC2, MMC4 - newly retipped with elliptical,  MMC4 - newly retipped with nude Fine Line, Beosystem 5500 - (Beomaster 5500, Beocord 5500, Beogram 5500, Beogram CD5500, Master Control Panel 5500, Beolink 1000)
Martynka
Verified by priklep
Thanks.
In addition to the sound and appearance, there is one more important reason for the renovation.
M70 in the living room gave an unpleasant odor in the air. Confusion of the old basement with the composition of waste paper. Like a warehouse with old, damaged books.
To eliminate it, I had to replace the filling, vacuum the inside of the boxes, change the material for the grill, beeswax gave the whole a pleasant natural aroma.
Martynka
Tomorrow I will take photo in daylight.
Martynka
And in daylight...
Now it's time to prepare some stands for this beauties.
chartz
Burgundy, France
chartz replied on Fri, May 24 2019 5:59 AM
Well done.
Now you need the tulip stands.
Jacques
Martynka
Now I have 2% tolerance caps from Falcon Acoustics
Page 5 of 5 (64 items) < Previous 1 2 3 4 5 | RSS
