Beoremote One and Beosound Core?
This post has 18 Replies | 4 Followers
jc
Posts 60
jc Posted: Tue, Sep 25 2018 12:38 PM
Does anyone know if the BR1 is able to control basic functions (next, previous, on/off, volume) of the BS Core?
spezializten
Posts 53
Yes you can do all basic functions and even more. For ex. all sources from the Beosound Core will be synced to Beoremote One. I'm struggling for the moment to add LIGHT commands which can be rerouted to Beolink Gateway.
Millemissen
Flensborg, Denmark
Posts 12,201
Also see this thread:
https://forum.beoworld.org/forums/p/35464/263200.aspx#263200
@spezialisten
If you have more information and maybe some pics, it would be fine if you could share it (there).
Razlaw
Posts 3,672
Razlaw replied on Sun, Nov 25 2018 9:08 AM
spezializten:
Glad to hear this. Have ordered a BeoRemote One for use with my Core.
spezializten
Posts 53
Some updates. I'm now running Beoremote One together with Apple TV. I think some one in B&O have made a REALLY good job because both Apple TV - MENU -> BeoRemote One HOUSE/MENU and Apple TV - TV -> Beoremote ON INFO-button works flawless!
What I did after that is Bluetooth paired the Apple TV with Beosound Core and every things works perfect controlling volume and of course LG Sampling (HDMI-CEC) is enabled on the TV which will let the AppleTV turn on / turn off the TV.
The only thing missing now, is the lack of sending LIGHT commands to the Beosound Core but I can live with talking to SIRI instead.
Razlaw
Posts 3,672
Razlaw replied on Wed, Dec 12 2018 3:36 AM
Received my BR1 today. Very happy with it. Seems to work perfectly with the Core including displaying the Tune in stations. Also works well in ir mode with my older equipment, other than one problem I have posted in a separate question thread.
Ditlev
Posts 42
Ditlev replied on Sat, Feb 16 2019 1:12 PM
Razlaw:
How did you pair the two - I am struggling to make my BR1 and core work together? How do I do it?
Been looking at the other threads here, and in the manual...YouTube etc etc.
Help?
BeoVishion
Posts 14
I think using the BR One BT is a great way of controlling the multiroom speakers as you can have an interface of what you will be able to play without having to go to a mobile device.
Firstly, what you'll need to do is go onto the B&O app, select your BeoSound Core> go into product settings> configure and then it'll take you into the internal settings of the Core - under remote controls you can open your BS Core for pairing and then go into your BeoRemote One BT,  press LIST, go down into settings> pairing> pair> "open for pairing" - once both are open for pairing they will connect and all functionality will work very similarly to when being used with a television.
All sources available on your BS Core will be seen under the "Music" button.
Vish
Ditlev
Posts 42
Ditlev replied on Sat, Feb 16 2019 2:15 PM
BeoVishion:
Vish
Thank you Vish!
The core part was all good. No problemo, but my beoremote does not have a ‘pairing’ option in List>Settings. Is it a different (perhaps outdated) version of BR1 I got my hands on? It looks like this (ie. I think its the first version):
Ditlev
Posts 42
Ditlev replied on Sat, Feb 16 2019 2:30 PM
It may not be the BT version I guess?
Though, it does have BT mentioning in menu ...
https://www.dropbox.com/s/hsvuuqjhgw66syb/IMG_0413.JPG?dl=0
Ditlev
Posts 42
BeoVishion
Posts 14
It seems you're using the original BeoRemote One - this has only the IR function and does not allow a Bluetooth connectivity.
The Bluetooth source that is appearing on your remote seems as though you have "product integrated" a Network Link Multiroom product to maybe a BeoVision - allowing you to play the Bluetooth source from your Multiroom through the BeoVision.
You would need to get an updated version of your BeoRemote One to get the "pairing" functionality - the new BeoRemote One BT does include IR communications, so you would be able to use it with dual functionality.
Hope this helps.
Thanks,
Vish
Razlaw
Posts 3,672
Razlaw replied on Sun, Feb 17 2019 2:28 PM
My Beoremote 1 was working perfectly. Then I made some setting changes and now I can not get it to work as it did before. I am sure I am missing something very simple. I have reset it and re-paired it with the Core. I also have it set to operate my BV7 in ir mode. The BV7 works perfectly. The Core is paired and I can set the my buttons. However, in the list of sources instead of showing Deezer and Tune In as before, all I have is Join. Additionally it is not showing the Tune In station that is playing as it did before. Any thoughts?
Thanks!
nico vercammen
Elversele, Belgium
Posts 162
I have/had the same problem.
As soon as I changed something in the "link to other products" menu the tune-in list etc came back. I just changed one "link to other products" pressed "verbinden" (connect) and the menu was back. I guess it is a minor bug ?
Nico
Razlaw
Posts 3,672
Razlaw replied on Mon, Feb 18 2019 12:53 PM
I was able to get the problem solved. Reading the user guide it appears there are two methods for pairing. The first method for the initial device and the second method for subsequent devices. As I only have the one device paired I re-paired using the first method and now all works as it should. I am not 100% certain this was the solution but I think it was. Also spent a great deal of time trying to remove the source Radio from the ir music sources. Removed it multiple times in the list but pressing the music button in ir mode continued to activate Radio. Finally I realized that the Music and TV buttons can cave a source assigned to them just as the My Buttons can and that Radio had somehow become assigned to Music.
Stan
Posts 607
Stan replied on Sun, Apr 14 2019 12:39 AM
Hi Razlaw,
How hard is it to switch between IR and BT mode.  It sounds like you're doing this just fine, but I thought I read somewhere that you had to switch between BT and IR mode...  can this be done just by creating IR and BT products in the remote list, or is there more to it.
I'm thinking about getting a BeoRemote to control a BV8 and Essence mk2... and I don't feel like screwing up the BR I have programmed for my Eclipse (at least until I get some basic questions answered like this one).
Thanks,
Stan
Razlaw
Posts 3,672
Razlaw replied on Tue, Apr 16 2019 3:14 AM
Yes, it is necessary to switch between modes. The process for me is as follows: Press list, then arrow up once which will take me to Core or Beo 4 AV in the display, whichever is currently active. Then arrow right which will then display both Core and Beo 4 AV. Use arrow again to select the mode to switch to and press go. Total of 5 button presses.
Stan
Posts 607
Stan replied on Wed, Apr 17 2019 3:06 PM
Thanks Razlaw.  This is very helpful.  Not ideal, but not too bad either. I think there's another Beoremote in my future.
Razlaw
Posts 3,672
Razlaw replied on Wed, Apr 17 2019 3:16 PM
Glad to help😊
Page 1 of 1 (19 items) | RSS
