Apple TV 4/4K Siri remote and Beovision
This post has 58 Replies | 6 Followers
soundboy
Posts 5
soundboy replied on Sat, Apr 11 2020 9:35 PM
madskp:
As mentioned by Guy a possibility might to connect to the DVI port of the BV7 to get the handshake between the TV and the ATV to let the remote know which IR signals it shall send
But even with that in place you will probably only succed with the ATV remote without the white circle
If only it was that that simple as Guy directed... :) I have tried everything, I almost always use forums to ask for help as a last resort...
@madskp with DVI I think I'm stumbling upon yet another problem... it never worked with my ATV. I'm not even sure if it would work with anything else. I couldn't get any signal, that's why I switched to SCART which is scaling ATV horribly... It is what it is.
 And I've already had my hopes high :)
soundboy
Posts 5
soundboy replied on Sat, Apr 11 2020 9:43 PM
I'm sorry for some reason I cannot edit my previous post. Two more things. I am I guess a happy owner of the ATV remote without white circle and with 257 firmware. Moreover, with the DVI, when I was researching how to make it work before it seemed to me, that it would not work because my Beovision 7 is not HD Ready... For 9311 version it's HD ready from serial 19xxxx and mine’s 18xxxxx. So I gave up and went with SCART-HDMI scaler.
Guy
Buckinghamshire
Posts 2,275
ONLINE
Guy replied on Sun, Apr 12 2020 12:27 PM
soundboy:
You'll get a much better picture if you use the DVI socket.  And it doesn't matter if your TV is not HD ready - this is simply an hdcp problem (google it!).  I use my Apple TV4 with a non-HD BV6-26.
I use one of these boxes to extract the audio, and it has the added advantage of removing the hdcp: https://www.amazon.co.uk/aoeyoo%C2%AE-Analog-Converter-Digital-Extractor-White/dp/B00NAJ4UM2/ref=sr_1_5?dchild=1&keywords=SOUTHSKY+HDMI+to+HDMI+%2B+Audio+Converter&qid=1586690544&sr=8-5
As stated earlier in this thread, initially connect the Apple TV direct to your TV's DVI socket using a hdmi to DVI cable.  The sound won't work, but this will hopefully trigger your remote to adopt the B&O volume control protocol.  Then insert the audio extractor and feed the audio into the corresponding input on the TV.
soundboy
Posts 5
soundboy replied on Sun, Apr 12 2020 12:56 PM
@Guy if this works it's pure gold! I remembered I've already read about hdcp before and it was the ultimate reason I went after SCART eventually. Didn't know how to ”break it”.
Thanks heaps! I'll post a reply once I try this one out, when the box has arrived.  Being able to watch my ATV through DVI on my Beo is so much more than I expected! OMG
madskp
Denmark
Posts 312
madskp replied on Sun, Apr 12 2020 12:59 PM
Another option that comes to mind is that you could initially connect it to another B&O TV with HDMI to get the handshake so the ATVremote transmit B&O IR codes. And after that connect it to your own setup.
I just tried to disconnect my Apple TV and take the remote to a BV6 I have in another room, and it was able to control the Volume of the BV6.
madskp
Denmark
Posts 312
madskp replied on Sun, Apr 12 2020 5:39 PM
I just updated the first post in the thread with info about the second generation Siri remote and firmware versions
Guy
Buckinghamshire
Posts 2,275
ONLINE
Guy replied on Fri, Apr 24 2020 11:38 AM
madskp:
Hi Mads - I meant to reply to thank you for updating the first post - this thread really is very useful for those who need (want) Siri remote volume control of B&O TVs. I am also interested to see how soundboy gets on!
madskp
Denmark
Posts 312
madskp replied on Fri, Apr 24 2020 6:20 PM
No problem. I think it’s always interesting to discover new features in the products I have.
On a side note I just got my parents Beocenter 6-26 because they were not using it anymore. So when I have a little extra time I think I will do some experimentation with the ATV remote on this
kai
Posts 329
kai replied on Sun, Sep 13 2020 11:19 PM
I have set up at  latest generation with bvis 10, it has the pu code for apple but it does not seem to work, is it possible to control tv with apple remote I could not seem to get it to work
madskp
Denmark
Posts 312
madskp replied on Mon, Sep 14 2020 5:16 AM
Unfortunally the second generation of the Apple remoe with the white ring does not seem to have the ability to control a Beovision TV with IR codes. So no luck there.
MVee
Posts 6
MVee replied on Tue, Dec 22 2020 10:05 AM
Great thread and overview, thanks for that!
For me it works to control volume with my SiriRemote (1st generation, from AppleTV 4 (HD) ) and my Beovision7-40 MK5 also switches on after a couple of seconds.
However, one question on that switching on: how to make sure my Beovision does not switch on in the 'TV' function, but in the 'DTV' function, to which my AppleTV is connected via HDMI? Are these defaults to be set based on preference? Now I still need to use Apple and B&O remotes to get started.
Thanks!
Guy
Buckinghamshire
Posts 2,275
ONLINE
Guy replied on Tue, Dec 22 2020 11:33 AM
Welcome to Beoworld!
I don't have a BV7, but from looking at the manual I think that you need to go into the CONNECTIONS menu, find the corresponding hdmi input and change AUTO SELECTION to ON.
But it's a bit of a guess!
MVee
Posts 6
MVee replied on Tue, Dec 22 2020 2:39 PM
Thanks for your reply Guy!
Put it to ON does not seem to do the trick, still going to TV first.
Tried to assign the HDMI A with the AppleTV to the 'TV' button as a work around, as that seems to be the default, but somehow can't seem to get sounds. Seems I can only assign AppleTV to DTV/DTV2?
Guy
Buckinghamshire
Posts 2,275
ONLINE
Guy replied on Tue, Dec 22 2020 2:57 PM
In order to use TV, did you disable the TUNER in the TUNER SETUP menu?
Also, I see in the CONNECTIONS menu that  that there is a SOUND INPUT option with each source.  Did you set this to the appropriate hdmi input?
MVee
Posts 6
MVee replied on Tue, Dec 22 2020 4:09 PM
It keeps me puzzled. Yes, have switched the tuner off, assigning it to the TV button seems to work and have the right HDMI A selected.
What I discovered meanwhile is that it has to do with the order of switching on devices. I need to switch of all devices. In case I wake up the ATV with its Siri remote also the BV switches on (to TV, which is the ATV), however, does not respond to the volume buttons of neither my Beo4 nor the Siri remote and sound is not audible in any way. If I do it the other way around with both devices off, switching on the BV with the Beo4 and than the ATV with the Siri remote it works.
It seems as if that was not the case when I had it connected to DTV. However now chanching it back does not solve the issue, keep having problems with the order and then it keeps switching to TV first, not automatically to DTV, which is the problem I was trying to solve...
Any thoughts or advice is very much appreciated, thanks a million!
MVee
Posts 6
MVee replied on Tue, Dec 22 2020 4:10 PM
madskp
Denmark
Posts 312
madskp replied on Tue, Dec 22 2020 8:48 PM
Its a little unclear to me if you wish to use the B&O TV command for the HDMI port connected to the ATV or if you rather like to use the DTV command.
However the SIRI remote will only transmit the TV command (the same as if you press TV on a B&O remote) as a turn on command, and there is no possibilities for other commands to use on the SIRI remote.
The Volume functions however will work with all B&O video related commands: TV/DTV/DTV2/DVD/V.MEM etc.
So your only option is to assign the TV command to the HDMI port as you have allready tried.
Your sound problem however seems odd.
Have you tried another HDMI cable?
Is the BEO4 showing TV in the display when you are not able to adjust the volume?
Can you try to use an other HDMI port on the TVto see if the problem persist?
Finally resetting the TV to factory settings and starting over might be an option if you are ok with setting things up again and not afraid of loosing settings?
Hope this might be helping you
Guy
Buckinghamshire
Posts 2,275
ONLINE
Guy replied on Wed, Dec 23 2020 9:55 AM
madskp:
I am glad that madskp has posted because I was running out of ideas!  The only other thing that I would have suggested was madskp's suggestion about trying all the other hdmi sockets because they do have slightly different specifications in certain setups (eg hdmi matrix).  Don't forget to change all the relevant setting in the CONNECTIONS menu as you swap the hmdi, making sure that the AUTO SELECTION and SOUND INPUT are correct.  You might just find an option that works!
Guy
Buckinghamshire
Posts 2,275
ONLINE
I am revisiting this thread because Apple have now brought out a '2nd generation' Siri remote: https://www.apple.com/uk/shop/product/MJFM3ZM/A/siri-remote
My first generation (earlier version, no white circle) siri remotes are still working well to control the volume on my BV6s directly via 440kHz IR, but I wonder if this new version will work in the same manner.  I suspect not, as the 440kHz IR capability seemed to have been removed from the later first generation 'white circle' remotes.
I look forward to hearing if anyone is able to test.
Page 2 of 2 (59 items) < Previous 1 2 | RSS
