Beovox cona
Not Answered This post has 0 verified answers | 8 Replies | 1 Follower
andersnaeser
andersnaeser posted on Tue, Aug 7 2018 3:20 PM
Hello
I'm looking for a beovox cona, and it is, of course, used.
I was wondering what i should be looking for when buying it?
I have the cx100 and I know that the membrane will break with time and I was wondering if there is a similar weakness with the Cona?
leosgonewild
Helsinki, Finland
Silver Member
I think the cons has rubber membrane. At least there was no issue with the one I had before.
andersnaeser
Is it easy to check though?
leosgonewild
Helsinki, Finland
Silver Member
Just look under it.
kallasr
Germany
Use a flashlight (app). That might help. On the Beoworld product pages you see a shot of the bottom as well. Not easy to check the condition of the membrane visually.
Ralf
andersnaeser
Okay, I will have to open it then?
Can I here if it's broken?
andersnaeser
andersnaeser
tph
Denmark
tph replied on Wed, Aug 8 2018 4:09 PM
From what I can tell, the loudspeaker driver is quite clearly visible under the grille at the bottom (see an example). It should not be difficult to visually inspect the surrounds.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
Page 1 of 1 (9 items) | RSS
