Problem with Beolab 4000..
Not Answered This post has 0 verified answers | 2 Replies | 0 Followers
MediaBobNY
Greenwich Village, NYC
MediaBobNY posted on Fri, Mar 9 2012 3:42 AM
One of my BL4000's just died.  Well, it didn't completely die - it senses an audio signal and switches from red to green when fed a source.  And I can daisychain a signal out of it to the other speaker.  But no sound comes out of it.  I've tried reversing cables/channels and played with the L-R-Line switch, all to no avail.  It also doesn't seem to make the same clicking sound that it used to when turning on/off.  It's about 10 years old.
Any ideas?  My technical skills would probably get me as far as changing a fuse, but that's about it.  Thanks in advance.
valve1
The south of France and occasionally Dublin Ireland
Sounds unusual, have you tried this swapping speakers to eliminate a cable/plug problem ?The fact you can daisy chain suggests the cable is not problem - but it is the only thing I can suggest.
Peter
Earsdon
Peter replied on Fri, Mar 9 2012 7:09 AM
Sounds like an internal component failure - unlikely to be a fuse - take it for service.
Peter
Page 1 of 1 (3 items) | RSS
