Beosystem 3 - RS232 pin layout to Beovision 4
Not Answered This post has 0 verified answers | 2 Replies | 2 Followers
Kiwi
Kiwi posted on Tue, Jun 26 2018 12:01 AM
Can anyone please help me with the pin layout for the RS232 connection between the Beosystem 3 and the Beovision 4 (with camera) ?
I already tried a straight cable and a null modem cable but still no luck. The screen doesn't power up and is recognised in the Beosystem 3 as a Panasonic interface TY-FB9FDD, which is simply the DVI interface.
When I use a Panasonic remote to power on the Beovision 4 (in the left bottom corner), everything works. So, I'm suspecting the RS232 cable.
Any help is welcome.
Roger
Norway
Roger replied on Tue, Jun 26 2018 11:48 AM
These are the connections/layout for the BV4 mkIII (with camera) RS232:
frog
Camberley UK
frog replied on Sun, Jul 1 2018 12:47 AM
Make sure you short pins 7&8 together - the beosystem won’t send commands otherwise.
Page 1 of 1 (3 items) | RSS
