Roasties 6000 quad returns
Not Answered This post has 0 verified answers | 24 Replies | 0 Followers
Craig
Yarm, United Kingdom
Craig posted on Thu, May 24 2018 6:31 PM
Roastie called round the other day bearing gifts........seems this little scoundrel has decided to misbehave, "standby lamp comes on.....but nothing else is working"..........will take a look inside, I'm suspecting a broken single strand wire.
Craig
Opened her up for a look and sure enough the standby lamp comes on, when standby button is pressed the relay engages with a click but nothing happens....however during my poking around the whole thing burst into life.
Craig
Craig replied on Thu, May 24 2018 7:17 PM
All function lamps illuminate on request and all looks well......switching to standby and everything goes off, pressing standby again powers everything back up.......but this isnt happening all the time.....looks like I have a intermittent fault somewhere.
Craig
Poking around the damaged relay (the cover has been broken in a past life) and in particular the tie wrap holding the cover in place interrupted the supply and everything went dead again......this looked suspect when last I had this apart. Removed the relay and the cover fell apart.
Craig
Replacing the relay without its damaged cover has resulted in the unit powering up and down every time........a test period is required but I'm optimistic that I have the culprit.....now if anyone has such a relay I would appreciate hearing from them?
Craig
Well.....reassembled everything, the relay now has better air circulation around it's coil and contacts due to the absence of a cover......not ideal I know but doesn't impact on functionality....dust may be a problem if its left for any length of time. So Dave next time your up here call in and collect it, I will give it a bit longer on test then store it away for you ;~)
square4
Hi Craig .
I have send a message to the guy who send me the tuning wheel for you, maybe he has the relay you are searching for. I let you know as soon as I hear from him.
Kind regards.
Henrik
Craig
Craig replied on Sat, May 26 2018 3:19 PM
Henrik
That would be great.....thank you so much ;~)
Craig
MrRoast
Stellar job as always Craig - New Zealand will run dry at this rate 😄 🍷
I have a second 6000 in bits with an intact (I think) relay cover, but have a hankering to get that one back to life again one day so ideally not cannibalise it.
If Henrik’s contact can find one then let me know and I’ll sort you out.
I’ll drop you a line next time we’re up 👍🏻
Craig
Craig replied on Tue, May 29 2018 7:31 AM
Dave....
Sounds good to me.
Craig
square4
square4 replied on Wed, Jun 13 2018 12:35 AM
Hi Craig.
My contact will send the relay to me later this week, as soon as I have it i will send it to you.
Henrik
Craig
Craig replied on Wed, Jun 13 2018 7:15 AM
Henrik
Thats very good news....thank you, let me know the final costs including postage and I will make a payment to you.
Best Regards Craig
MrRoast
MrRoast replied on Thu, Jun 14 2018 12:06 AM
👍🏻 great!
square4
Hi Craig.
Now i have finally received the relay,i will send it to you as soon as possible.
Henrik
Craig
Craig replied on Tue, Jul 3 2018 7:21 AM
Henrik
Thats great news....your a star! please email me the final cost and I will reimburse you soonest.
Regards Craig
Page 1 of 2 (25 items) 1 2 Next > | RSS
