Beogram 3000 bearings and idler
This post has 21 Replies | 3 Followers
Saint Beogrowler
Saint Paul
Posts 779
Saint Beogrowler Posted: Wed, May 9 2018 6:24 PM
Beogram 3000 type 5228, 5231, 5241. I just installed the new idler wheel from Martin and infused my bearings with oil and took lots of pictures to share. I’ve struggled with this table going too fast or too slow in the past and received lots of help here for which I’m very thankful. I love this thing.
Saint Beogrowler
Saint Paul
Posts 779
Beogram supported upside down. Not on the switch or the arm of course.
Motor
Saint Beogrowler
Saint Paul
Posts 779
3 nuts
Saint Beogrowler
Saint Paul
Posts 779
2 clips
Screw for switch
Removed motor
I set this close to the table and left the wires attached.
Saint Beogrowler
Saint Paul
Posts 779
2 nuts for the motor suspension, the 1 on the right is already removed in the photo. This spring motor suspension works great at isolating the noise from the powerful motor and idler.
Removed bracket
Lift springs up off shaft
Saint Beogrowler
Saint Paul
Posts 779
Here is the location of the two bearings we are going to infuse
Loosen screw on the pyramid of speed control and remove from shaft
Saint Beogrowler
Saint Paul
Posts 779
Remove the 3 bolts from the motor housing.
Holding the nuts requires a narrow wrench.
Lift off housing
Removed
Saint Beogrowler
Saint Paul
Posts 779
Pry tabs gently to remove bearings. I pry one less than the other to allow for easier reinstall.
Saint Beogrowler
Saint Paul
Posts 779
Details of how the two bearings are housed from when you first open them
Bottom
Top
Saint Beogrowler
Saint Paul
Posts 779
I used SAE 30 oil, like an old VW.
Heated oil added, vacuum sealed following the Beolover YouTube video
I didn’t take pictures of the heating or sealing process incase my significant other were to see what I’m using food prep areas and tools for. Careful handling, hot oil is hot.
Saint Beogrowler
Saint Paul
Posts 779
After 24 hours I heated the bearings with a butane torch and reapplied to the oil. Probable not needed though.
After another day I reinstalled.
Saint Beogrowler
Saint Paul
Posts 779
Idler removal. 1 screw
Old on the left. New on the right.
New idler installed
Saint Beogrowler
Saint Paul
Posts 779
Idler installed. Bearings installed. Pyramid of speed control installed.
I’ve replaced the original euro 50hz pulley with a pulley from a 60hz motor. I found snugging the pyramid screw not too tight is helpful for future speed adjustments.
Saint Beogrowler
Saint Paul
Posts 779
As it says in car repair manuals; installation is the reverse of removal.
I’m really happy with how quiet the new idler wheel is and how consistent the speed is now.
Christian Leicht
Aarhus, Denmark
Posts 71
Seems nice! But why do you heat the oil?
I use the process described here. It doesn't mention anything about heating the oil.
Kind Regards,
Christian Leicht
https://leicht.io - B&O Custom Parts & 3D Models
Paolo3500
Posts 3
Paolo3500 replied on Mon, Mar 22 2021 7:36 AM
Hello Beogrowler,
can you tell me where you got the new idler wheel from? I think mine is causing some speed issues for my Beocenter 3500 so I'm thinking about chaning it.
Cheers!
Saint Beogrowler
Saint Paul
Posts 779
Paolo3500:
Hello Beogrowler,
Cheers!
From Martin at Beoparts.com
Peter8300
Denmark
Posts 64
Peter8300 replied on Sat, Jul 31 2021 5:42 PM
Great description thanks, very helpful.
How do you guys get the motor centered when reassembling it?
And do you replace the felt?
Peter
Peter8300
Denmark
Posts 64
Peter8300:
Peter
No one? Do you just play it by ear or? ;-)
On another note I'm trying to upgrade my membership to Silver and it seems something is out of order, I'll start a thread about that at the appropriate place.
Peter
Saint Beogrowler
Saint Paul
Posts 779
Peter8300:
I don’t understand your question. It only goes back together one way.
Peter8300
Denmark
Posts 64
Saint Beogrowler:
In my original printed copy of the BG 1202/3000 service manual (see pic) it is stated that the motor should be centered using two gauges before it is bolted together. I found a scanned copy online where this is not mentioned.
Peter
Peter8300
Denmark
Posts 64
Ok I installed the motor and put everything together and then the noise was unbearable. I sounded like something was grinding inside. Took it apart again and this time tried to center the motor using four round toothpicks. There's two "holes" on each side of the rotor, I stuck the toothpicks in those before bolting the motor together and then removed them again. Put everything together again and voila no noise.
Sorry forgot to take pictures, next time..
Peter
Page 1 of 1 (22 items) | RSS
