Beolab 6000 double sided woofer tape.
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
max65special
max65special posted on Thu, May 3 2018 4:43 PM
I have a pair of Beolab 6000 speakers. I have bought new woofers but need to replace the double sided tape that holds them in place. Does anyone know exactly which type I need & where to buy it from? Thanks.
joeyboygolf
Ely, Cambridgeshire, UK
They should be held in with self tapping screws!
Regards Graham
leosgonewild
Helsinki, Finland
Silver Member
OP is talking about the gaskets.
joeyboygolf
There are no gaskets unless you mean the lengths of black drought excluder between the woofers.
Regards Graham
Page 1 of 1 (4 items) | RSS
