Compatible Electric Floor Thermostat
Not Answered This post has 0 verified answers | 4 Replies | 0 Followers
Aleksei
Russia
Aleksei posted on Fri, Apr 27 2018 10:15 AM
Hello,
The thermostats that are mentioned in all the topics are very nice, however most of them work with water heating systems.
I am looking for the electric floor thermostat that may be used with BLGW. Something like Devi (http://www.devismart.com/) or HeatIT (http://www.heatit.com/heating-control/floor-heating-thermostats/heatit-z-trm2/). Looking on the list of the drivers, I could not find something similar. Does anybody know what brand/model is compatible?
Danfoss' Devi looks to use proprietary protocol, but HeatIT claims to be open for other systems.
https://beointegration.wordpress.com/
1:BV7+BL7.1+BS4+BL6000+BV6+BL2000+MLGW+Beo4
2:BV7+BL7.4+BL3500+BM5+BL3+Lutron GE/Sivoia QS+HikVision+Dune+LinTronic+BLGW+Beo4+Beo5+Essence remote+BeoTime+BeoLinkPC+BL4+KNX+... BeoMaster900
Aleksei
Russia
Short update: Currently I decided to go the difficult way. I plan to build (expensive!) KNX system with thermostat and actuator, and then try to bridge KNX and BLGW.
Aleksei
Russia
I am almost ready to report the results, but have one question.
is it possible to get on BeoLink (2) screen the window, that will only indicate the value, received from KNX? For example, if I would connect to Temperature/Humidity sensor, it might be good to see the temperature and humidity values on the screen. Is there any ready tools for that?
Aleksei
Russia
Finally, I have connected the electric floor thermostat.  Here's the report with screenshot:
https://beointegration.wordpress.com/2018/09/03/thermostatknxblgw/
There are actually couple of ideas for Ikatu, so if someone from them is reading, would be helpful.
chucky
chucky replied on Wed, Sep 12 2018 7:12 PM
Nice Aleksei!
Sometimes it can be hard to integrate everything in the gateway, but at least you have result.
It seems feedback from any temp sensor in the BLGW is a pain
Page 1 of 1 (5 items) | RSS
