Sound from tape deck after stop BC9000
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
riis
Denmark
Silver Member
riis posted on Mon, Apr 16 2018 8:59 AM
I have just finished refurbishing my old BC9000. The servo board has been re-capped (thanks to Dillen ) and the cd-player works again. The loose glass panels and the plastic frames have been cleaned and attached with new foam tape ( 6mm x 0,5mm ).
The tape deck also works fine, but I can hear a sound from it after stop. The sound remaims if I choose other options like aux, radio etc, and first disappears when I set the BC on stand-by.
Is this a normal behavior?
The white side- and front panels have turned yellowish, probably from nicotine and uv-light. Is there a way to bring them back to white? I have different things without effect.
/riis
tournedos
Finland
Many B&O cassette decks have this funny feature, the motor and capstans remain turning once you have "accessed" the deck. I suspect BC9000 does the same and this is normal.
Unfortunately there's usually nothing you can do about yellowed plastic, other than replacement.
--mika
riis
Denmark
Silver Member
riis replied on Mon, Apr 16 2018 10:24 AM
Thanks Mika. I can live with both the sound and the yellowed sides. No big deal.
-riis
Page 1 of 1 (3 items) | RSS
