B&O system with non B&O TV
Not Answered This post has 0 verified answers | 20 Replies | 0 Followers
johnheartfield
johnheartfield posted on Sat, Apr 14 2018 11:21 AM
I know there are other threads on a similar topic but as time goes by so do solutions...
I have a BeoVision 7-40 HD (the early one with no HDMI) with an attached BL 7.4. This is the centre of a system with a BeoSound 9000 and 2 X BL 8000's at front and 2 X BL 6000's at rear. There is also a BeoLab 2. Everything is "plumbed in" using ML. The speakers are the older ones.
I want to change my TV to a non B&O option. Question is how can I keep the rest of my system in place and still make everything work as is with minimal relocation of wires etc? The 9000 is on the wall with wires plastered in!!
Inferno82
I think only with beosystem 3?
johnheartfield
Had not thought of thatSmile. Thank you. I know you can still buy them. Anyone with experience of using this with something like an LG OLED?
OldJack
Split
Or Almando ? There are posts about Loewe oled/Almando integration.
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones A8,A9 keyring,Bottle opener,Wine Set,4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,Beoplay A1,Oppo udp-203, LinTronic.
johnheartfield
Thanks for the suggestion. Always worry a little when things are run by an app given Apple’s lack of continuing support and updating issues for them some times.
Raeven
Silver Member
Raeven replied on Sun, Apr 15 2018 4:47 PM
As I have reported in an other post I have installed the Almando in a similar setup. In order to connect the ML you need to add a B&O link active. Works perfectly for me. The app of Almando is (actually two app's either Apple or Android) is only used to setup the speakers (volume etc). Once this is done you never use the app again.
Good luck!
kai
kai replied on Sun, Apr 15 2018 6:23 PM
Hi Raeven
I hope you don’t mind me asking I have asked a question on something similar, beovision 4-50 non hd, I’m going to replace this with a non bango tv, however I still have the beocentre 2, do I simply use a beolink active to connect the beocentre 2, and still use the radio and cd command, how is the volume controlled
Mikipidia
@raeven
What is the app called in the apple app store? I can’t seem to find it, thanks in advanceYes - thumbs up
New: Beolab 50's, Beolab 18's, Beovision eclipse, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3.
Mikipedi4 on YouTube
https://www.youtube.com/c/mikipedi4
Old: Beolab 1's, beolab 2, beovision 10-46, overture 2300, beolab 8000's, beolab 4000's, beovision avant 32" etc. etc.
Raeven
Silver Member
Raeven replied on Mon, Apr 16 2018 3:17 PM
Hello the app is called: Almando Control. But I think the app is still in test by Apple. If you buy an Almando product just mail them and you will receive an invitation to Testflight then you download and run the app. The android app is normally available in the google store. I work with the Apple app works perfectly. If you want I can post some screen shots.
Mikipidia
Hi Reaven,
yes please, I'd be very interested in that. I still have an eclipse, the key word being ''still''. iam not that happy so iam looking at all options they way I feel I should've done when I bought my new setup.. anywho I'd love to see how it works and what you could do with speaker control etc. thanks!
Aussie Michael
Melbourne, AU
I’m going the axiim q route for my Sony OLED A1
Dante
Sao Paulo - Brazil
Silver Member
Dante replied on Tue, Apr 17 2018 4:12 AM
Hi Reaven,
How would you rate the Almando DAC? Did you notice any quality drop in sound due to use of a non-BO TV?
Sweden
Martin replied on Tue, Apr 17 2018 6:54 AM
Hi Mikipedia,
why are you not happy with your Eclipse?
I am satisfied with mine besides that I experience sometimes NO sound when starting Deezer or MUSIC from NAS. But I got message from my dealer that this software bug is beeing corrected very soon.
I really like the PQ of the Eclipse and that the Tv support all major PQ format (dolby vision and HDR).
Best regards
Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K
Sweden
Hi Mikipedia,
Best regards
Epsilon20
Axiim is WISA compliant so have scope to add B&O speakers later.
Beovision Eclipse 55 Brass Edition with Oak covers and Brass Orbital stand
Beolab 50s silver & Oak, Beolab 18 Brass with Smoked Oak, Beolab 18 Rose Gold with Maple Covers, Beolab 19 Black.
Page 1 of 2 (21 items) 1 2 Next > | RSS
